HS-925MG: Speed?
Old 08-19-2005 | 06:47 PM
Davross's Avatar
Default HS-925MG: Speed?
Hi guys,
I have 2 HS-925MG Servos. One is running with a Gm v8 ESC, HFS-03MM reciever, the other a HFX ESC and same (seperate) reciever. B4 and XX4 We are the chassis. My question is, what voltage are these servos running at? Should it 6.0 volts?
I have seen other brands of servo with lower specs make these look shamefully slow!!!
Davross is offline
Old 08-22-2005 | 02:05 AM
Davross's Avatar
I guess this question is'nt worth answering then???
Davross is offline
Old 08-22-2005 | 06:08 AM
Joel Lagace's Avatar
it runs at 6volts and lower depending on 4 or 6 cells.
IT runs at 0.08sec at 6volts normal votlage from an esc using 6 cells
Joel Lagace is offline
