-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   wierd servo (https://www.rctech.net/forum/ask-hitec/743-wierd-servo.html)
ozzyNEOdriver 10-01-2001 06:19 AM
wierd servo
i've got a metal gear 615mg ultra which has the following problem.
when i turn left the gear skips. if i attempt to hold it at the skipping point it twitches.
ps; non of the gears are broken. i opened up the servo and i noticed the middle gear, (not the one the servo horn goes on and not the one on the oposite end of the servo, yet the middle one which has a pin going through it) moves to the side when i turn left. instead of keeping it's position it shifts (as if the pin isn't keeping it straight) to one side and that's what is giving the "skipping" effect.
why is this happening to a $110 servo? (australian dollars)
ozzyNEOdriver 10-02-2001 05:35 AM
anyone?
ozzyNEOdriver 10-04-2001 05:26 AM
echo echo echo echo............hello hello hello........
TSR6 10-04-2001 10:35 AM
Ozzy - Go post a message on Any Topic Thread Gary mentioned using e-mail notification to keep up with the BB, and he may not have seen your thread
Gary Fliegel 10-04-2001 02:49 PM
Ozzy. the pin will move with the cover off. The cover keys into the pin to hold it stationary. Are you sure there aren't any missing teeth in the gears somewhere? How old is the servo and what have you been using it in? TTYL.
Gary F.
ozzyNEOdriver 10-04-2001 09:28 PM
gary i ran it for about 2 race meets in a rs42. i was using a 15fe.
i still get this effect i described above even with the cover on.
Gary Fliegel 10-05-2001 04:58 AM
If it took a couple of good whacks and the servo saver was to tight it may have been damaged. I will find our where you can get it fixed. I'll get mike to post a reply for you here. TTYL.
Gary F.
ozzyNEOdriver 10-05-2001 06:01 AM
it's never taken any wacks
i live in australia. i already sent it to melbourne. no word yet from hitec in melbourne and i sent it out the 21st of sept
Gary Fliegel 10-05-2001 11:16 AM
OK, if you have it out for repair you should have it soon. TTYL.
Gary F.
