Throttle Servo
Old 03-25-2013 | 08:28 AM
Default Throttle Servo
I am writing this to ask if a HS 81 servo can be mounted on an OS.81 four cycle engine. The servo will be attached to the mount lugs of the engine using 1/8" phenolic sheet. I have mix opinions from fellow modelers, some say the vibration will be too much for the servo and others say it should be fine. My goal is to mount the servos on the front side of the firewall (in this case on the engine) so setting up the throttle servo will be easy and the set up will not be affected when the engine is removed. This is for a B-17 project.
Your thoughts?
Cheers,
Keith
speedbrake is offline
Old 03-27-2013 | 11:13 PM
I thought this thread was a link to Hitec and they would answer customer questions, yes/no?
