Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Hitec Crx Agressor Casing Broke >
Old 02-23-2005 | 04:55 PM
Default Hitec Crx Agressor Casing Broke
I have a Hitec Aggressor CRX witht the spectra module in it. I was racing and all of the sudden the steering kept spinning.. I didn't know what had happened.. I unscrewed the steering wheel to see that the steering stopper has been snapped off and that it is attached to the casing.. Can i get a whole new casing for this? How much would that cost? I am affraid to glue it back because it opened up the case a little bit.
TC3SFR0MHE77 is offline
Old 02-24-2005 | 05:00 AM
vulso's Avatar
Hello,
Same thing happened to mine, as well as a few other people here. I had a thread on it a while back here but it must have been deleted. I sent mine in for warranty repair and it came back fine. I also use a little longer screw to hold the steering wheel on to remove some of the slop. It will take a little while but you'll get it back fine.
Just call Hitec customer service and they will take care of you.
Regards,
DFS
vulso is offline
Old 02-24-2005 | 06:17 AM
Tres's Avatar
Company Representative
vulso is correct, contact: [email protected]
They will take care of you.
Tres is offline
Old 02-24-2005 | 01:40 PM
Sounds good, How long is a little while? Can you not order a case for it?
When you got your radio back, was it a new one or the same one repaired?
Old 02-25-2005 | 12:45 AM
vulso's Avatar
Mine was the same one repaired. I would let Hitec do the fix case otherwise you will void your warranty. Mine has worked fine since being repaired. I missed a few races while it was being repaired, it took a few weeks. But it is worth it.
Tres.........Thanks for the Wonderbread sticker!!!!!!!!!!!!!!
vulso is offline
