Interference
Hi. I just purchased a brand new Hitec Agressor 3 FM 75mhz radio system a few days ago.
I am getting literally 200 times the interference with this system than I was getting with my crappy Airtronics AM 27mhz that was only 50 dollars. It makes no difference how far away I am from the car, I still get interference. My servos just jump all over the place, and thus my 9 pound 55mph buggy does as well.
What things can interfere with 75 FM? I would like to hunt down whatever is doing it and bash the living daylights out of it
Or is there some other problem causing what APPEARS to be interference?
Chris
Or is there some other problem causing what APPEARS to be interference?Thanks
Chris
HFS-03MM 3 Channel Receiver, one HS-325 Deluxe Servo, one HS-635HB servo, Switch harness and Dry AA Battery box.
Yes, it's gas. I'm not sure if it does it while it's not running, I'll check tomorrow.
I discovered today it also does the same thing in my other gas 1/10 sedan, with the exact same radio, same model reciever (not exact same one), one hs-311 servo, one hs-325hb, switch harness and dry AA battery box.
It never did this in 4 years until I installed this new radio system in it, that is what has me baffled.
Alkaline, 4 cell. Soon I will be using NIMHs though, and occasionally NICD.
Today I learned that my main problem is chain-link fences. They totally mess with both my cars within 6 or 7 feet. A good thing to know. Never had that problem with 27 AM though....
The 1/10 sedan, however, jumps around whenever I am near it, but as soon as I walk a few feet away, it stops. Apparently in that case, my body is the interference. The buggy doesn't do that. A little odd...
Any suggestions would be appreciated.
Interesting, since rechargables usually have 1.2v with no drain, and alkalines having 1.5v with no drain. I guess that means that alkalines, with a drain, drop below 1.2v?
