cg-330
Old 11-13-2004 | 08:57 PM
primusblowsgoat's Avatar
Default cg-330
i recieved one of these in a trade, need a lil info on it, how old is it?
will it do nimh?
thats about it a link to a manual would be cool too
primusblowsgoat is offline
Old 11-14-2004 | 05:52 PM
Tres's Avatar
Company Representative
http://www.hitecrcd.com/Chargers/Dis...d/chargers.htm
Manual
The economical CG-330 incorporates a unique glow igniter battery charging feature and a “Boosted Charging Method” that allows it to charge up to 24 cells (28.8 Volts) from a 12 vDC source.
Applications: 4-24 Cell 270-3000 mAh NiCd Battery Packs
Input Voltage:9-15volts DC (5 Amps min)
Charge Current:
Main Circuit: Adjustable 0.5- 5.5 amps
Glow : 1.1 amp
Features:
DC-DC Charging w/boost circuit
Delta Peak W/auto trickle
Delta Peak CutOff
Initial Cutoff Error Override
Input/Output Polarity Protection
Tres is offline
Old 11-15-2004 | 08:54 AM
so i assume thats a no on the nimh huh?
Old 11-15-2004 | 09:19 AM
Tres's Avatar
you are correct.
Tres is offline
