Receivers for KO
Old 10-20-2004 | 02:54 PM
OB42TC3's Avatar
Registered User
Default Receivers for KO
Does hitec make any receivers that work for KO? with KO crystals; I like the 03MK, but I have a 03mm that doesn't work with my helios.
OB42TC3 is offline
Old 10-27-2004 | 10:45 AM
MikeMayberry's Avatar
Company Representative
The 03MK will work but you will need the Hitec Xtal. The 03MM should work with the KO Xtal. I'll have to test this.
Mike.
MikeMayberry is offline
Old 10-27-2004 | 10:49 AM
Mike - I would be interested to know the outcome of any testing as I own two of the 03MM receivers, one on 75mHz that I use with Airtronics receiver crystals and my Multiplex transmitter and another on 27mHz that I haven't used as yet. I also have a KO radio, but mine is the older EX-1 Mars system on 27mHz that I was hoping my second receiver could me mated with.
Let us know what you find out please.
SteveM is offline
Old 11-02-2004 | 08:44 AM
OB42TC3's Avatar
Registered User
My hitec 03mm won't work with the ko crystal. Would a futaba crystal work? Are the crystals pos/neg shift? My KO radio is a Helios 75 mhz.
OB42TC3 is offline
