Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Receiver Shift and compatibility >
Old 04-29-2002 | 04:34 PM
Default Receiver Shift and compatibility
Ok I know that Ko, Air, And Jr all work on a positive shift and Futaba and Hitec work on a negative shift which leads me to my question.......Lets say I have a Hitec radio, will a futaba reciever work as well as the hitec? Also lets say I have a JR radio, will a KO or Airtronics receiver work also since they are on the same shift??
Now I know that most companies will tell you to use only the receiver that is the same as the radio but is this really true. I have a friend that uses a Ko radio and all Jr receiver's.
Raydee is offline
Old 04-29-2002 | 06:38 PM
Tres's Avatar
Company Representative
Yes & yes......
You can use other brand Rx's as long as you use that brand x'tals in them.....
If you use the Hitec DCX Rx's, you must use the Hitec DC x'tals no matter the shift.
Tres is offline
Old 05-20-2002 | 07:05 PM
2canSAM's Avatar
R/C Tech Elite Member
Just to make sure I have this right. I can use a Futaba Transmitter with a Hitec Receiver as long as I use Hitec Crystals in both? and if it is a DCX receiver I have to use DCX crytsal in both?
2canSAM is offline
Old 05-20-2002 | 07:25 PM
Tres's Avatar
2canSAM: Use that x'tals that go with your Tx....
If you have a Futaba Tx, Use Futaba X'tals in the Tx, Air, use Air x'tals & so on....
Use Hitec Dual Conversion in the DCX....
Dual Conversion is for the Rx only....
Tres is offline
Old 05-23-2002 | 01:48 PM
Default okay so..
the Hitec dual conversion will only work with dual conversion crystals...
Is there anyway I can trade in a like new Dual conversion rx and a new Hitec HFS-04MI 27 mhz receiver for something I can use..like servos?
sprintr is offline
Old 05-23-2002 | 03:54 PM
Tres's Avatar
You might try the FOR SALE section on this board. But, there is no trade-in type of deal through Hitec.....
Tres is offline
Old 05-23-2002 | 05:29 PM
okay..i figured that is what I`d have to do..but I figured I`d give it a shot..thanks
Mike
sprintr is offline
Old 05-28-2002 | 09:40 PM
Default JR-R1 needs receiver.
I have a JR-R1 tx and i need another receiver, can theHitec DCX Rx's be used? and if so what kind of crystals are required?
Do i have to change the module in the r-1 to use the DCX?
thanks.
fuse01 is offline
Old 05-31-2002 | 06:40 AM
Tres's Avatar
fuse01: Yes, you can use the DCX...
27MHz
part# 24327
75MHz
part# 24375
No, you will not need to swap the module....
You will need to use FM, not PCM...
Order the Dual Conversion Hitec x'tals....
Tres is offline
Old 06-03-2002 | 09:44 PM
RAP66's Avatar
Sine we are talking about the JR R1. Does HItec make a Spectra module that will work with the TX. I'm getting tired of Hauling all kinds of Xtals..
For that matter how about one for the KO Mars EX1?
if they are available what are the part numbers so I can be sure to get the correct module(s).
Rich
RAP66 is offline
Old 06-04-2002 | 05:47 AM
Tres's Avatar
Hard Jokur(Rich):
Sorry, no plans for a module for either one of the radios.....
Tres is offline
Old 06-05-2002 | 04:21 AM
coastaltony's Avatar
New question
Does Hitec have separate FM Spectra modules using 27, and 75 bands?
coastaltony is offline
Old 06-05-2002 | 06:10 AM
Tres's Avatar
Sorry, Spectra is made only for the 75MHz band.
Stock # 24475
Tres is offline
Old 06-05-2002 | 06:28 AM
tres
