Hitec HS605BB?
Old 07-16-2004 | 09:37 PM
LosiFromHell986's Avatar
Default Hitec HS605BB?
Hey Hitec Guys,
I just got a XXX4 off of eBay and it came with a HS605BB servo. I was wondering if anyone could tell me how old this is? Still in production? How much is it in stores? Is it all metal geared?
Thanks In Advance,
Jeff
LosiFromHell986 is offline
Old 07-17-2004 | 05:31 AM
Tres's Avatar
Company Representative
Hitec HS-605BB
Size: 1.5 x .8 x 1.6
Speed: .13 sec/60°
Torque: 92 oz-in
Dual bearing
retail: $59.95
It is not metal geared
Tres is offline
Old 07-18-2004 | 12:21 PM
it isn't? The (don't know what it's called, I'll try my best) output shaft looks like it's metal? Is it easy to break? I have it in a XXX4 without a servo saver, should I put one in?
Old 07-18-2004 | 03:55 PM
Tres's Avatar
Is it a BB or MG after the 605?
BB stands for ball bearing & MG stands for metal geared
Yes, you need a servo saver with a XXX4
Tres is offline
Old 07-18-2004 | 05:37 PM
It's BB after the 605, as I posted, but the output shaft(correct term?) looks to be metal. I'll confirm it in awhile, I need to go put a servo Saver on.
Old 07-18-2004 | 05:40 PM
Tres's Avatar
They may have put a metal gear set in it then.
Tres is offline
Old 07-18-2004 | 06:27 PM
Yeah, I'll open it up tonight and check it out.
Old 07-18-2004 | 08:07 PM
okay, here's the scoop. It says Hitec HS605BB on the Label. But when I opened it up, I found no plastic gears that I could see. Sooo does that mean I have a Hitec HS605MG? What's the specs on that?
Old 07-22-2004 | 06:46 AM
Now I'm having a different problem.
When I run the car, it has a MAJOR hard time turning right, but left is just fine...
Old 07-22-2004 | 08:08 PM
okay.
I took it out, thinking maybe the Buggy was binding somewhere, but when I undid the Ballcup and turned right on the steering wheel. It took a full second to reach full Right! I don't understand it, It worked great until I put the motor in and tried running it...
Is there anything I could do before sending it to Hitec? I took it apart to make sure nothing was stuck in the teeth of the gears and such, but it still doesn't work right.
Old 07-24-2004 | 11:41 AM
I'll be calling Hitec/RCD on monday to see how much repairs would cost.
Thanks for the help
Jeff
Old 08-15-2004 | 04:44 PM
Sending the Servo in on Tuesday, thanks for the replies, tres.
Old 08-15-2004 | 04:46 PM
Tres's Avatar
NP
Tres is offline
