2.4 module for 9c
Old 12-11-2009 | 11:28 AM
Questions?? 2.4 module for 9c
what is involved in switching to the new 2.4 module from hi-tech and where can i find more information about it.for my futaba 9c,will the 7 channel receiver work in gas ignition planes without interference.
78-lt is offline
Old 01-07-2010 | 10:57 AM
Default Hitec 2.4GHz systems
Futaba 9c conversion with hitec 2.4 system -Report - 12/27/2009
Have personally tested AOK in 8UAP amongst others and currently swapping & using a Spectra Pro between FF7, Eclipse & Optic 6 for demos at field.
Spectra 2.4/Optima 7 Combo
Hitec RCD Product Details 2009
Hitec RCD Optima 6, 7 & 9ch Receiver Manual
Hitec RCD Spectra 2.4GHz Module Manual
Spectra Pro Antenna Mast Fitting to other than Aurora TX may also be of interest.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Post Script:
Spectra Pro 2.4Ghz is also compatible with other Module Type Transmitters that use the same Futaba/Hitec module shape/size/pin slots. e.g.:
5UAF, 5UAP
7UAF,7UAFS, 7UAP,7UAPS, 7UHF,7UHFS, 7UHP,7UHPS
8UAF, 8UAFS, 8UAP, 8UAPS, 8UHF,8UHFS,8UHP, 8UHPS
(8FGA, 8FGH as non-module radios can not be accomodated).
9CA, 9CH, 9CAPS, 9CAFS, 9CHPS, 9CHFS
10CH, 10CA (10CAG or 10CHG as non-module radios can not be accomodated).
A.T. is offline
