-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Servo jitters (https://www.rctech.net/forum/ask-hitec/309038-servo-jitters.html)
JizzardKing 07-02-2009 09:47 AM
Servo jitters
So my 7955s have the jitters. My project is not RC but an aiming device, so the jitters, while very small for servo standard, get magnified a lot in this system.
I have read and it seems the potentiometer is the cause. The pot gets between two values and the servo jumps between two positions.
I was thinking about a gearbox for stability, added accuracy, and the raw vertical support (the load on my system is vertical).
If I do decide on a gearbox, and this is where I am somewhat confused, is that I don't want to go overkill on the x:1 ratio. The 7955 has 450 steps per 90 degrees, so, if I went with a 5:1 would that increase my resolution to 2250 steps/90 degrees? Or would the resolution still be 450/90, but now my rotation is slowed by a 5th?
Or maybe there a solution other than a gearbox?
Billy T. 07-06-2009 07:22 AM
The gearbox will be slowing down the servo a 5th. The resolution will remain the same. Have you tried increasing the deadband to see if anything changes.
