HS-7955TG
Old 06-11-2009 | 08:28 AM
mattwoodcraft's Avatar
Default HS-7955TG
i have 4 of these servos now i maybe its something im doing but one of tghem i have in my steering in each of the cars and my truggy just will nopty get full lock i have adjusted all the end points to the max this is the first time i have come across this is the servo able to get more throw programmed into it at all ?
thanks very much
mattwoodcraft is offline
Old 06-12-2009 | 07:47 AM
Billy T.'s Avatar
Hey Mattwoodcraft,
You should be getting 90-100 degrees of full travel in the servo depending on where your EPA's are set. With our programmer, you can get up to 180 degrees. Are you getting at least 90 degrees of total travel at 100% EPA?
Billy T. is offline
Old 06-12-2009 | 03:00 PM
i have the epa set all to 150 % on my handset to get close to full lock and all the trims are set to max this is the only servo i am having trouble with i have only just purchased this servo ...
how do i get hold of the programmer to get more steering ?
thanks
Old 06-22-2009 | 08:12 AM
i cant seem to fing the programmers for these servo where abouts can i get one
Old 06-23-2009 | 12:47 PM
Billy T.'s Avatar
The HFP-20 and the HPP-21 can be purchased through Tower Hobbies.
Billy T. is offline
Old 06-23-2009 | 02:01 PM
thanks i had not looked there
