Servo Horn Screw Size?
I hate the phillips head screws that hitec uses. What size screw do I need for the 59** and 79** series of servos to convert it over the hex head.
2.6 x 8mm
Originally Posted by BRENDAN LUGO
(Post 5726589)
2.6 x 8mm
where can yu find this screw??? i only see 2.5 screws, i cant find 2.6, why did they have to use such an uncommon screw size?? |
With an allen head I dont know where you would find it. Maybe micro fasteners? :confused:
The stock screws can be found in our screw package #55802. |
Originally Posted by suryo88
(Post 5729279)
found another source. Did not check on shipping costs.
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=57581 |
jr makes them, amain sells them.......the screws- http://www.amainhobbies.com/product_...ducts_id/26475
In a pinch, they are the same size as the endbell screws you would find in an open endbell electric 540 motor... Useless information... UNTIL YOU'RE IN A PINCH!!!!!!!!
Originally Posted by l3asher
(Post 5726548)
FYI
We have the 2.6 x ? hex heads in several different lengths (5,6,8,10,12,16mm). Starting from $2.95 for a 12 pack. 50 or 100 packs even less per piece! |
Originally Posted by Billy T.
(Post 5872942)
HPI makes the exact screw that you need in a hex head. Z421 is the part number, 2.6mm x 8mm machine thread.
i added a bag of 50 the last time i ordered something from them. probably overkill, but i'll never need to buy 2.6x8 screws again (until i lose them). |
yo
i had this same problem with my jr 9100's servos. the stock screw just backed out on its own. is there any other screws for the jr horn maybe thats not phillips? the only one that backed out is the front steering one with the aluminum horn.
The smaller hitec metal gear servos take a 2.25mm screw. I just tap them to 2.5mm. Too much of a pita to keep special 2.25 screws for a servo.
| All times are GMT -7. It is currently 09:31 AM. |
