5955 case weak?
Old 01-25-2009, 10:18 PM
Default 5955 case weak?
I have now had 2 5955's have the entire motor assembly come thru and break the bottom cap on the servo. If you look at where the screw goes thru them its very thin and looks weak. Has anyone else had this problem?
SuperDaveNT is offline
Old 01-26-2009, 10:57 AM
Hello,
What is the servo in? Also when this happens is it a result of a crash?
martin salgado is offline
Old 01-26-2009, 09:50 PM
Its in a Losi 8T, they were both from pretty big air but I had Airtronics in there before and did not have this problem!
Old 01-27-2009, 11:46 AM
Hello,
We have not had an issue with the cases on the HS-5955 servos. How long have you had the servos?
Old 01-28-2009, 04:19 AM
Trader Rating: 19 (100%+)
i ran a 5955 on my savage and then on my crawler and both performed great. Granted i wasn't getting huge air on either but i never had any issues.
kurt. is offline
Old 01-28-2009, 03:24 PM
Trader Rating: 51 (100%+)
I had the same problem with my 8T going over REALLY big jumps. The radio tray has too much flex. You need to add a radio tray brace to fix the problem.
Cyberacer is offline
Old 01-29-2009, 08:50 AM
Hello,
I was just going to suggest that. You may want to lift the servo up a bit. Maybe shimming it a bit. Also check the chassis to see if there is any marking on it from the servo hitting.
Old 02-02-2009, 08:53 AM
The servo tray brace and the spacers in the losi kit fixed the problem for me.
Old 02-03-2009, 05:32 PM
I have the brace and the servos are both shimmed up.
