-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   HFS-03MM Receiver Question (https://www.rctech.net/forum/ask-hitec/25990-hfs-03mm-receiver-question.html)
SteveM 10-14-2003 11:07 AM
I own several Multiplex Profi pistol grip transmitters and would like to know if your HFS-03MM FM receiver will work with my transmitter. It it is compatible, can I use the Airtronics single conversion FM receiver crystals I already own or do I need to use only Hitec crystals?
I have been using either a Novak Xxtra or a Novak Mercury receiver with Airtronics SC receiver crystals to date.
MikeMayberry 10-14-2003 03:27 PM
I haven't tested it but if the other receivers you mentioned worked the 03MM should work too.
Mike.
SteveM 10-14-2003 03:35 PM
Thanks Mike. I have one on order now and I hope it works for me.
I know that with FM radios, Hitec and Futaba are compatible (negative shift) and Airtronics, JR and KO are also compatible (positive shift).
I am worried that my Multiplex Tx might not be compatible with the Hitec Rx due to a difference in the FM shift modes. If this new receiver is universal (like my Novak Mercury is) then I should be OK. I'll have to test things out when my new receiver arrives. I am surprised that this hasn't been tested at the factory.
