HS-65HB
Old 08-23-2008 | 11:37 PM
minispeed's Avatar
Default HS-65HB
I've got a HS-65HB for my rc18t. My question is does someone make a servo strap or brace to hold it to the chasis? if so do you have a product number?
Thanks for taking a look.
minispeed is offline
Old 08-25-2008 | 01:19 PM
DFroyd's Avatar
I used the same servo in my 18t. I used the mounts that came with the servo using the stock inner location on the chassis and elongating the outer hole in the chassis.
DFroyd is offline
Old 09-11-2008 | 09:42 AM
skuter-race-ta's Avatar
Default servo hs-65
hi just a quick question that needs a quick answer..
does this servo will fit in kyosho mini insferno st????
skuter-race-ta is offline
Old 09-18-2008 | 10:55 AM
MikeMayberry's Avatar
Company Representative
Yes it will.
Mike.
MikeMayberry is offline
Old 09-18-2008 | 07:24 PM
Originally Posted by MikeMayberry
Yes it will.
Mike.
thanks bro.....
Old 10-07-2008 | 09:45 AM
Default HS-65 casing
Hi was wondering where can i buy the casing for the servo?
All my mounting was cut off
thank you
FastisGood is offline
Old 10-07-2008 | 09:50 AM
BRENDAN LUGO's Avatar
thank you
http://www.horizonhobby.com/Products...rodID=HRC55418
http://www3.towerhobbies.com/cgi-bin...&I=LXPVV5&P=ML
BRENDAN LUGO is offline
