servo savers 645MG
Old 08-18-2003 | 07:07 PM
corvettecrazy's Avatar
Default servo savers 645MG
i just got a 645MG and I have to say that either all the stock ball ends are larger or the servo savers from hitec really suck.
I am now down to 1 servo saver attachment thing that will work for my steering servo and it flexes ALOT.
am I missing something or are the holes in the servo saver pieces way to small?
corvettecrazy is offline
Old 08-18-2003 | 07:47 PM
Tres's Avatar
Company Representative
You will need to drill the servo saver to fit the ball studs.
This is standard for most all servo savers.
Tres is offline
Old 08-19-2003 | 05:15 AM
i drilled it and then when I screwed it in the plastic cracked.
Old 08-19-2003 | 10:57 AM
MikeMayberry's Avatar
What part are you talking about?
If you screwed the ball studs in and the plastic cracked then you did not drill them large enough.
Mike.
MikeMayberry is offline
Old 08-20-2003 | 06:38 AM
the red one
Old 08-20-2003 | 01:53 PM
The stock horns that come with all servos are intended for control links on airplanes. You'll just need to make the hole larger to accomodate the ball studs. A 3/16" drill bit would be fine, 7/64" would be best.
Gary Fliegel is offline
Old 08-20-2003 | 08:48 PM
also why does it hum so much?
and how come when i turn the transmitter off (testing/working on new failsafe) it moves about 1/8 of a turn?
Old 08-21-2003 | 05:05 AM
Tres's Avatar
If it's humming all the time, check your steering, it may be binding somewhere.
If it moves when you turn your radio off, that would have to do with your failsafe.
Tres is offline
Old 08-21-2003 | 09:24 PM
but the fail safe is connected to the throttle servo and the hitec is my steering servo...trust me I have not screwed up my wiring.
Old 08-22-2003 | 04:06 AM
If you shut your radio off and the car is still on, there is no signal controlling your servo. It will move. If you do that at a track, it will move more than an 1/8th of a turn.
The humming is from loads being applied to the servo. All it needs is for you to put a little side load on the wheels and it will hum because its trying to stay where your Tx is telling it to stay. Its all normal servo functions. TTYL.
Gary
