Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Problem- Hitec 5625 Servo >
Old 08-13-2003 | 12:59 PM
Default Problem- Hitec 5625 Servo
Hey,
I have an HPI Savage that I have put a JR XR3 radio and receiver into. With the radio and receiver I also installed an Airtronics 94359z for steering. Eventually I bought a Hitec 5625 Digital for throttle servo duty. I plugged the 5625 in and turned on the radio and receiver. The servo wont respond to commands. It wont return to center. After hitting the gas I noticed that as soon as I let go of the throttle it would immediatley go to full brake. I tried every setting in the radio and nothing seemed to solve the problem. Can someone please help me?
ChrisE is offline
Old 08-13-2003 | 01:25 PM
Tres's Avatar
Company Representative
Kinda confused.
If it doesn't respond to commands, how does it go to full brake after you hit the gas?
There are a couple of things to check.
Which servo horn are you using?
Are you using ABS on the radio?
Tres is offline
Old 08-13-2003 | 03:15 PM
Sorry let me clarify.
I put the servo in the truck and put it out on the track. I start going down the straight and as soon as I let off the throttle it immediately goes to full brake. I tried changing all the throttle settings on the radio and nothing fixed it.
1.using stock HPI horn. I can only use the HPI horn because of the way the throttle linkage is setup stock. The HPI horn has a built in servo saver.
2. The JR XR3 does not have ABS.
ChrisE is offline
Old 08-13-2003 | 04:15 PM
Tres's Avatar
It looks to be using Futaba radio equip.
If so, the stock servo saver would NOT have the number of teeth for a Hitec servo(24).
Does it work ok if you re-center the servo saver for a short time?
Tres is offline
Old 08-13-2003 | 04:58 PM
Nope. Could it be that the servo saver is too weak?
ChrisE is offline
Old 08-13-2003 | 09:01 PM
popsracer's Avatar
ChrisE;
Sounds like you need to remove the servo ARM (saver), allow the servo to re-center, then reinstall the arm.
Use the ATV/EPA adjustment (if any) to set the throws and you should be all set.
Also make sure the Splines on the servo Arm match the brand of servo you are using (in this case Hitec). If it slips, this could cause the problem you describe.
popsracer is offline
Old 08-14-2003 | 09:06 AM
MikeMayberry's Avatar
What are you using for a RX battery?
MikeMayberry is offline
Old 08-14-2003 | 10:47 AM
Im using a Elite 1100mah RX pack from Ultimate Hobbies in Orange,CA
ChrisE is offline
Old 08-14-2003 | 02:30 PM
That's OK, so I would pull the horn off and see what the servo does with no load.
Mike.
Old 08-28-2003 | 05:46 PM
Default Help....
Mike,
I also have a 5625 servo installed for steering on a NTC3 which intermittently wouldn't go back to center. Any tips on rectifying this bug would be greatly appreciated.
thanks,
p.s.
this servo has been sent in for service twice last year because it just stopped working for no apparent reason.
BongR is offline
