hs-65mg case
Old 12-31-2007 | 12:29 PM
Default hs-65mg case
I have a 450 Trex and of course crash a lot I finally cracked the top case of a hs-65mg. The replacement case from hitec PN#55418 came with a different top than the one that broke and doesn't fit by just using the new top. The new top has a post inside to hold the little reduction gear in place.It has no hole in the post it like the top I am replacing. Do I need to change the whole case or is this a problem?
lethal is offline
Old 01-02-2008 | 08:07 AM
BRENDAN LUGO's Avatar
Company Representative
It sounds like you may have received a mispackaged item. Please contact our customer service to resolve this. 858-748-8440
BRENDAN LUGO is offline
Old 01-02-2008 | 11:31 AM
Default change it all
Well I answered my own ? It works if you change the whole case not just the top. Was trying to not have to replace it all but it works. It seems that the case is updated.
lethal is offline
Old 01-02-2008 | 01:38 PM
UltegraSTI's Avatar
i wonder if it was updated. b/c info says m1.7, a M2 screw and tap both thread in loosely. i finally had to tap it to M2.5 to get a screw that worked w/a servo saver. works great, but boy a lotta work. perhaps there is an update and the screw is now a M2.3 (that size is annoyin too) like the larger servos despite its smaller overall gear size. that inturn maybe behind your case issue
R
UltegraSTI is offline
