-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   please HELP!!! (https://www.rctech.net/forum/ask-hitec/193385-please-help.html)
Haulenass210 11-29-2007 09:16 PM
please HELP!!!
ok i have a question for everyone i need some help figuring out this problem i have with my radio/esc/servo. I have a ko helios, with a hi-tec 6965 servo, and a quantum competion 2 esc. everything works fine with this combenation. I have another car i am going to use this JR900s servo in. when i plug it all in and turn it on it looks as if everthing is ok, but when i have the throttle at any position, and turn the wheels, the motor pulses and loses power. i have no idea what is going on. if anyone could help or give me any ideas of what to do that would be great because i am at a loss. Both servos are digital servos.
thanks
4u2nv 11-29-2007 11:25 PM
I had the EXACT thing happen when I was using Hitec servos with my spektrum reciever.. (the 525's).. A hitec rep told me they were difected, so I sent both of them back to them, they tested them and said they were fine. So I tried installing them again. Same thing. Tried two different brands of servos and they worked fine.. I think with some recievers, they just dont work. Maybe this is the case with yours, it sounds exactly what was happening with mine.. Hitec told me they should work fine, but I could never get them to cooperate.
looper 11-30-2007 12:07 AM
sounds like the BEC is going south on it does it do this with other servos?
Tres 11-30-2007 04:29 AM
Looper is correct, sounds like a BEC issue...
Try using the Spektrum cap on the Rx.
Haulenass210 11-30-2007 07:05 AM
i have 2 hi-tec servos it does it with one but not the other. and it does it with the jr 9000s
