-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   crx module compatiblity ? (https://www.rctech.net/forum/ask-hitec/178197-crx-module-compatiblity.html)
jhs3373 08-22-2007 03:13 AM
Does anybody know is there a module that compatible with the hitec crx radio? I want to control my mini-z using the crx, but hitec doesn't have a FM to AM conversion module like others radio (airtronic/sanwa, futaba and KO). Mini-Z is running on 27MHz AM freq. Any advise? Thank you.
Tres 08-23-2007 07:04 AM
The Futaba AM module will fit in the CRX, but I'm not sure it will work.
As many of the Futaba guys run our Synth. 75MHz module.
Bermbuster 08-25-2007 11:45 AM
I too had the same question.....a hobbyshop owner posted in a mini z forum that the futaba am module works.....he stated to use a quality crystal.
my son has a hitec crx....I have a helios tx w the mini z module.....
my plan was to get a module for him. My helios tx took a crapper and i was stuck without a tx....so i bought the futaba 2pl....it was $65. The Futaba am module is about $40. Now I have rethought my idea of having just one tx......In my travels if I find the am module cheap i will get one otherwise the 2pl works awesome......
jhs3373 08-26-2007 10:37 PM
Hi..thank you for the input. Bermbuster...what do you mean by using a quality crystal? For AM, do we need to match the x'tal brand reffering to the Radio/TX brand ? i.e if we used futaba radio than the X'tal should used the same brand also ?
Tres 08-27-2007 06:43 AM
AM 27Mhz is universal, there is no POSITIVE / NEGATIVE issues like on 75MHz.
You should be able to use any brand X'tal.
However, I would stay with the Hitec x'tals due to the quality of some of the 3rd party ones as Bermbuster stated.
jhs3373 09-04-2007 04:02 AM
Hi again. I have already try using the CRX with the Futaba AM module and it works :nod:
