Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
1/8 buggy steering servo??? >
Old 07-02-2007 | 08:34 PM
Jason Halvorson's Avatar
Default 1/8 buggy steering servo???
im sure you have gotten this question a million times, but i was wondering what the perfect hitech servo would be for a 1/8 buggy??? i just race, and i just installed a new HS6975HB for throttle/brake duties and im so impressed with it that i would like to use hitech for all my servos....
Thanks in advance, Jason
Jason Halvorson is offline
Old 07-03-2007 | 10:40 AM
I would suggest using the Hitec HS-5985 servo or the HS-5997. The torque specs and speed are very close to each other. Either servo will work great.
I would lean more toward the HS-5997 because it is Titanium. We have not seen any wear or breakage with that servo.
martin salgado is offline
Old 07-12-2007 | 06:57 AM
mog ruith's Avatar
hi im new here to this rc hobby, just would like to know how do yo select servos? i mean theres servo for heli, plane! but ho do i select a servo thats meant for buggy?
mog ruith is offline
Old 07-12-2007 | 08:23 AM
BRENDAN LUGO's Avatar
Company Representative
By size, speed and torque. Understanding the type of vehical the servo will be used in and the type of use/abuse it will see will determine what you should use there. For most of us we have been in the hobby for a number of years and have had to go through a trial and error aspect to understand the types of loads a certain application will put on a servo.
BRENDAN LUGO is offline
Old 07-12-2007 | 02:21 PM
Further to Brendan's reply and until Hitec's old servo 101 pages are up on their new web site, suggest Helihobby's 101 - Servo FAQ & picking the right servo for the job will give you a good knowledge of servos. Before purchasing a servo, to obtain detailed comparisons, check out the servo page at Hitec Servos, open and read the full specification sheet for each servo.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 07-13-2007 | 05:56 PM
mog ruith's Avatar
thanx alot will read up n get back to you guys
Old 07-16-2007 | 09:21 AM
Get a HSC-5995TG. It's bullet-proof. Install it once and forget. Your buggy will wear out before that servo will...
Cyberacer is offline
Old 07-17-2007 | 08:46 AM
The 5955 would be the servo to get then, not the 5995. The 5995 is a robot servo and uses a slightly different pulse than the normal R/C servos. Plus it has 180 degrees of travel so in order to use it for R/C you have to decrease your end point travel and will loose all your resolution.
Old 07-17-2007 | 04:28 PM
Sorry I meant the 5955.
Old 07-24-2007 | 08:41 PM
Davidka's Avatar
Is there any reason I shouldn't use a 5975HB for throttle in my 1/8 buggy? The speed and torque are right for the application but I am worried the amp in the servo wouldn't hold up. I have one as a spare.
Davidka is offline
Old 07-25-2007 | 08:04 AM
My only concern with it being used in 1/8 scale would be the possibility of stripping a gear especially if you are using ABS brakes. This environment is very brutal on servos.
Old 07-29-2007 | 09:54 AM
what is the difference between the 5975 and the 6975??? i use the 6975 for throttle/brake is this a good servo for that duty???
Old 07-29-2007 | 09:57 AM
good call it works great for me....would this also be a good steering servo for a truggy or should u go bigger???
Old 07-30-2007 | 08:18 AM
The 6975HB is a updated version of the 5975HB. These servos will work to the th/br but for 1/8th scale a metal geared servo would be better.
Old 07-30-2007 | 08:22 AM
This servo would work fine. If you want to go "bigger" take a look at the 5998TG.
