Another regulator/amp draw question!
Running two 5955 servos in a buggy/arena truck - The Novak 3A regulator enough?
Running one 925 and two 945 servos in an LST - The Novak 3A regulator enough? Also, when there is too much draw through the Novak regulator, what happens? Servos just don't perform? Thanks. Chris |
Under heavy loads 3 amps may not be enough. If you exceed the amp rating of the BEC usually all that happens is that the servos will hesitate for a second until the amp load falls back under the rating of the ESC. :tire:
| All times are GMT -7. It is currently 06:43 PM. |
