Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
digital servo issues... >
Old 03-25-2003 | 08:04 PM
Default digital servo issues...
Hi! This is my first post, but I need your input! I recently ran my car, and it of course, got dirty and wet, but still worked beautifully. After the run, I used nitro cleaner to get the garbage off, like every other time. This time however, after a half hour after everything dried, I switched everything on to make adjustments, and the HS-5625 servo smoked. Long story short, it only moves in one direction now... What can I do? Is it salvageable? I liked that servo...
Thanks for your help in advance,
-Casey
caseyntc3 is offline
Old 03-26-2003 | 07:14 AM
Tres's Avatar
Company Representative
Sounds like it's gone....
contact: Mike
By what is stated, this would not be covered.
Do you get the same thing on the servo if you swap Ch. 1 with Ch. 2 on the Rx?
Tres is offline
Old 03-26-2003 | 11:48 AM
Thanks for your help! Yes, the same thing happens. I've currently replaced it with a 5645 for brake duty and everything is quite happy again. I've only had the one in question for not quite 2 mos., and this has never happened! Not even to my lesser servos.
Old 03-26-2003 | 12:13 PM
Tres's Avatar
It's hard to say.....
Servo price would have very little to do with this...
Most servo's are not water-tight....
Liquids and electronics never mix well.
Tres is offline
