Servo Recommendation
Hi im fro, Australia and im looking for a nigh speed under.10 sec 60 and high torque 6-8kg servo. I will be using it with a JR XS3 syth system or KO Propo Mars R/ Helios 10 With and without Spektrum and running LRP or Nosram ESC with 1.2amp min 5 volt BEC.
At the moment im running 625mg 645mg 925mg 945mg but have gliching problems when i run digital servos in the anologe systems, and again when i run anologue servos with the digital system. I would like to be able to change between the radio gear without having to change servos.
These servos (i need 4) will be used for Steering on a B4/ XXX BK2/ XXX tM2.
What would you recommend?
Cheers
Simon
Cheers
Simon
The 925 (now 965MG) is a good choice but the BEC amperage and voltage of the ESC could be a problem. You really need 2+Amp 6V for the high performance servos.
Also, any servo should work with any system digital or analog.
Mike.
Mike.
