Can I salvage this Novak Havoc Pro SC ESC and motor?
I've dusted off an old OFNA Jammin' SCRT10 with super low hours on it. When I got it I purchased the Havoc Pro SC ESC combo with the non-Ballistic motor option. It's a sensored, brushless setup, as many of you know. However, the truck will only run for a couple minutes before everything cuts out. I know the battery and radio are good because I tested them on another truck. I've tried resetting the ESC several times, checked temps, etc. I've read threads that mentioned a firmware upgrade but since Novak is no more that could be tough. I just replaced another Novak ESC and motor combo because the ESC was not compatible with non-sensored motors.
I'd love some advice on troubleshooting and hopefully salvaging this motor if the issue turns out to be the ESC. The motor has about an hour of run time on it and I'd hate to chuck it. Thanks in advance for your feedback.
unlikely.. you can try and add a fan .
R/C Tech Elite Member
ESC
If the ESC is SENSORED ONLY, then I would try to find a SENSORED motor to run instead of what you're trying to do. Or a ESC that will run either in SENSORED or NON-SENSORED mode. I have a unbranded Castle Sidewinder V2 ESC that is NON-SENSORED & I'm running a Tekin Redline 4 or 6 turn without problems. You can get the unbranded Castle on FleaBay for like $30 or something. You can find the Tekin on their website for like $24, so not a major investment for either.
As for a fan, it's not really going to help with the setup you're currently running. The sensor wire tells the ESC the timing of the motor (position of the rotor). The fan will help the ESC stay cool & it will cool the motor when mounted.
novak had there own sensor wire layout that was unique t them.I dont know it that esc motor combo fell into that area..I never liked novak due to that and other reasons..I know there was a web link to what esc where in that .I dont think its still up I looked. id just invest in another esc motor combo and save myself the hassle.
