Boss RC Motorsports
#226
Clint (STLNLST)- How could I fry my motor & ESC if it's running at low temps?? Granted it was cooler in the afternoon, but if my temp was at 112 deg, I would assume if I ran during the day it would only be in the 140 deg range. What would you suggest my FDR would be?
Thx-John
Thx-John
#227
Thx-John
Thx-John
#230
Ran your settings yesterday Nate and all I can say is "wow", the car was fast. Sorry the driver wasn't! Finished 5th, 2nd and 3rd in the three mains. I need to work on my TOP set up a little more, but Thanks again for the HP.
#231
Had a decent day yesterday on the dirt oval. TQed once again with the latemodel, this time powered by my BOSS 8.5. But I got flipped by a guy 4 laps down while leading with a lap on the field and 45 seconds to go, ended up fighting back to 2nd. My new edm problems all day, burned up a sensor in my 6.5 (not a BOSS), my mamba max pro went up in smoke on the bench, and my borrowed novak havoc 13.5 system thermalled in the main with 30 seconds to go while running 4th. Nate expect a package in the mail, I got some work for you lol.
#232
Nate, please check your PM.
#233
#234
Nate,
Just came back from racing at my local track. The track will be the site for the 2010 ROAR Asphalt Nats. I ran Spec 17.5 class today with a LRP Sphere ESC & TQ'd after 1st round. I geared your motor to 3.83 & my temps after the quals was only 139 deg!!!!! My second run the sensor cable got cut, so I had to pull over. We ran 2 qualifiers, & in the Main i came in 2nd. I think some were running ramping on their ESC You can really see the speed difference. We had some time to practice after the races & I switched to my updated Tekin RS on v208. Ran the same gearing & WOW!!!!! A totally different BEAST! I was keeping up with guys running ramping ESC. At this time it was cooler & at the end of my run the temp on the motor was 112 deg.!!!! I'm ready for the Nats!!! Thanks for a great motor!
#235
Had another good day on the dirt oval. Qualified third for latemodel and got the win finally. I have had the fastest car for three weeks but i keep running into problems. My edm was runnin awesome really fast low in the corners and almost just as fast up high. But the little things got me again. While battling for the lead with 30 seconds to go the screws came out of my Servo mount on the left side. But it was a great day of tuning for the biggest race of the year on my schedule, the KDOC. Hopefully I will be able to bring home some more trophies for BOSS.
#237
Registered User
Originally Posted by L.Fairtrace
It was good seeing all the TOP shirts at the race this weekend at Jackson. Would of liked to see a couple more that planned to attend but stuff happens.
The car worked awesome for me all weekend long and allowed me to TQ and win both 13.5 and Mod against a good field. I ran a similar setup that I posted on here about 3 months ago, but I can post it again if anyone is interested.
Hey Larry, Just purchased one of the Boss 17.5 Motors,Ceramic, Fan combo . Would you mind sharing your settings on your tekin and spur/pinion you run on your photon. The track I'll be running on is about the same size as Jackson. Will your 13.5 settings work ok with a 17.5? Also timing on motor. thanks.
#238
Nate- I had EJ run my BOSS 17.5 in his Photon & he got right off the bat the fastest lap in one of his qualifiers. I could not get the speed I wanted in a non-ramping setup, so I decied to let EJ get the best out of this motor in a ramping setup. Thanks for a great motor!
John
John
#239
R/C Tech Elite Member
John
John
If it's TC with a Tekin running 208 no timing I'd say you'd need to have Max motor physical timing and a high 3 or low 4 FDR
#240
Yes this was at the ROAR Nats. I ran with the Tekin 208 Spec Class Profile. My FDR was 3.91. I can try with the same gearing I used with the other brand motor I ran, which was 3.74 & see if I get the same results. The Nats is over now, so I will run my BOSS motor with ramping using Nate's setup he sent me.
