Pro-match Batteries
#1531
Yeah, 10ea #1157 Light bulbs,make sure to use a cutoff device of some kind to stop the discharge at 5.40 volts then put the pack on the tray for about 20 to 30 minutes and you should be good.
#1532
Could u suggest a cutoff device to get? Does Dean's make a cutoff device with-out buying the whole discharger with the lights & stand?
#1533
Honestly yodace I am not aware of anyone else that makes a cutoff device. The Deans setup is the only way I know of. Maybe someone else here can chime in if they know of an alternative.
#1534
There's always the $89 Novak alternative
#1535
Novak makes a cutoff switch? He is looking for a cutoff switch to put in line with his discharge lights.
#1536
What other cutoff device are out there to buy? Who also sells the deans discharger/cutoff device?
#1537
Thanks for the info>>>
Do they ship pretty fast?
#1539
I build my own
I use an automotive accesory relay. Its pretty easy to build, my son built one too. If you want more info, send a PM.
You can set the cut off voltage when you build it. Mine stop at 5.4 volts.
David Root
David Root
#1540
Hi Erika. The brown santa sled dropped off the batteries today. Thanks!
#1541
The dude that drops off my presents needs a large vehicle.
#1542
It's been a while since he visited me. I guess I been a bad boy.
#1543
LOL @ Chill
Yeah I am still waiting on the Big Brown Truck to bring mine.... Guess I have been bad also,LOL
#1544
Rod, YGPM regarding Portland.
#1545
Got it...flying for a couple of hours is better than driving half a day
