BMI Racing Discussions
#8386
Originally Posted by tmunno
Darren any more New Zealand titles to add to your impressive resume??? Lynn and Toni are tring to get ready for the roar nats in Oct. Toni is learning everything all over with a new BMI Mi2. Lynn is racing her old BMI TC3 and doing well. Hope to see you at the Snowbirds!!!!
Snowbirds, I would absolutely love to but I am still paying for the trip last year to worlds. I think my partner would divorce me if I went to the States again this year.
TimXLB... the PM message was meant for protc3. Although I to am thinking seriously about the lower cg mods. Because we run out doors all the time on unpreparred surfaces I think it may work really well. But I will wait for John BUll and others to do a little testing first before I look at it.
#8387
Yea..if a low cg mod car won't work for carpet....
then forget it. I sure do like the idea of it. I would like to run less camber and have faster corner speed.
I can't imagine BMI making a chassis for TC companies that change their chassis design every 4-6 months. Just my two cents.
#8388
Originally Posted by JayBee
JayBee:
Hi,
At this time I believe that B.M.I. does not have any plans of producing a Yokomo BD chassis Kit. I will keep you posted.
please e mail me at [email protected] so I can keep in contact with you about the BD chassis.
Thanks for getting back to me I'll keep in touch
Hi,
#8389
Here are a few pics of my BMI TC4.
#8390
Darren she was the only one at her local track running a TC4. A good friend of mine let her try out an MI2. She liked it!!! He sold her his second MI2 and she is doing better!!!! Tell your wife that it's a shopping trip to the USA, and bring her!!! This way she will let you come over here!!!!
#8391
12th BMI damper tube
Hi
currently running the 12th conversion and have it setup with Ass damper discs. I have the damper/straw tube motor top plate but not the tubes/straws.
which make tubes/straws would you suggest I buy as there are a few out there?
Also, anyone know if there are any lowered motor pod plates oher than those with the conversion? website only shows pic of conversion
#8392
jason is putting the finishing touches on the lowered bulkheads. If you go to the 1/12 or the bmi 1/12 there are some pics. we should see them back next week. I would call and get an order in if you want some.
#8394
Oooooohhh.... you shouldn't be tempting me. It can only lead to bad things.
#8398
Originally Posted by protc3
im waiting on 3mm c/f buddy.should be here in about 2 weeks.i will keep you posted
I look forward to hearing from you.
Question, Can the new motor mount be used with both thicknesses of chassis or are there seperate motor mounts for each thickness.
Would I be able to use the 3mm chassis with the thinner top deck and new motor mount if I wanted to.
Are the chassis coming with the centre support now or are they extra. I made one up for my current chassis and found since I have done that I have not stripped any spur gears.
Cheers
Darren
#8399
Fatbear...
you can use whatever thickness you want with the TC4 BMI. You can use the 2.5 or 3mm upper deck on a 3mm chassis. The new motor mount and 3mm chassis won't strip gears. In fact, with a 3mm upper deck and chassis little to no flex. It should work great for carpet.
#8400
TC4 Motor Mount
Does anyone have details of the BMI Motor Mount for the TC4? My BMI uses the stock TC4 mount and its slower having to either loosen the top deck or remove the mount through the bottom of the chassis when you want to pull the motor - we sometimes have super fast race turnarounds due to lighting curfews, and sometimes every second counts, and the motor mount on my old BMI TC3 was great.
So is there something similar for the TC4? I tried the BMI web site with no luck.
MIKE
MIKE
