Like Tree73Likes
Ask Team Tekin
Old 06-20-2010, 05:34 PM
  #526
John, Check the motor. Same thing happened to me and the motor had died without letting out magic smoke
Matt
Matt_N is offline
Old 06-21-2010, 09:53 PM
  #527
Will Tekin's team make software on Hotwire for iPhone or other mobile?
B.S. is offline
Old 06-22-2010, 01:55 AM
  #528
Trader Rating: 21 (100%+)
From what I've heard they are BUT there is a problem on Apple's end that is holding it up.
lidebt2 is offline
Old 06-22-2010, 07:59 AM
  #529
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys
anyone have some good rc settings for 17.5 TC asphalt rubber tire on about a 160 foot straight. I was FDR about 6.83 last week and just didnt feel right with 50 and 15 . . .
thanks
Chris
Chris08527 is offline
Old 06-22-2010, 08:07 AM
  #530
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
Originally Posted by Chris08527
hey guys
thanks
Chris
there are alot of setups in the rs thread.what is your setup
20 SMOKE is offline
Old 06-22-2010, 12:10 PM
  #531
Trader Rating: 152 (100%+)
Default Tekin RS Pro Question???
Can the Tekin RS Pro handle a Novak HV Ballistic 550 4.5 brushless motor???
bluebon88 is offline
Old 06-22-2010, 02:33 PM
  #532
From Tekin website: http://www.teamtekin.com/rs.html
RS Pro
Controls: Forward/Brake/Reverse
ON Resistance: 0.00005 Ohms brushed fwd mode, 0.00015 Ohms brushless mode, 0.00015 brushed fwd/reverse mode
Input Voltage: 4-9 Cells, 3S Lipo
BEC: 6.0V/3.0A
Motor Limit: None
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.3 x 1.00" x .60" (33 x 25.4 x 15.25mm)
Weight: 2.3oz with included 12G wiring
lidebt2 is offline
Old 06-22-2010, 04:45 PM
  #533
20 SMOKE's Avatar
it will work but you may have to run a second cap(i would do it anyway) is it going in a 4wd SC.
20 SMOKE is offline
Old 06-22-2010, 06:43 PM
  #534
PrimeAKF11's Avatar
hey guys,
I am going to be testing a 5.0T motor in my TC at my local track this weekend. So far I have been running a 10.5 with my RS Pro. Is there anything I need to do before hitting the track? I've read things such as putting 2 caps instead of 1 and putting a fan on the ESC but I've never had a problem with 1 cap and no fan when running a 10.5.
PrimeAKF11 is offline
Old 06-23-2010, 07:14 AM
  #535
Team Tekin
Randy_Pike's Avatar
A second cap will help with esc temps, and it won't hurt anything while running spec motors either.
Make sure your esc setup is correct for the mod you're using. Check our website for a Team driver setup like Jason Moberly's and build from there.
Randy_Pike is offline
Old 06-23-2010, 08:13 AM
  #536
20SMOKE,
It will be going on the Jammin SCRT10. Anyone have a pic of how it looks to run two caps.
Do you guys stack them up or side by side or what?
Old 06-23-2010, 09:40 AM
  #537
20 SMOKE's Avatar
stack them
20 SMOKE is offline
Old 06-28-2010, 02:06 AM
  #538
mdowney's Avatar
I'm running a new XRAY T3 with an RS Pro and a Redline 21.5 for practice while I get used to my first on-road car. For practicing on asphalt I need a recommendation for a spur + pinion combo. I have the stock 84T/48P spur installed at the moment but I can switch to a 64P spur (114T seems to be a good place to start). I want something that will give me a good feel for the car before I start racing it in Aug when our season starts.
Suggestions?
mdowney is offline
Old 06-28-2010, 04:01 AM
  #539
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Suggestions?
When people talk about rubber tire touring car they usually discuss gear ratios by talking about their final drive. FDR = (spur / pinion ) * internal ratio. Using the 48 pitch gears you specified you would be at a 3.325 which is too low (too big of a pinion). I would recommend you try to get to a 5.5 FDR and then alter your ratio from there. 5.5 will be wow, but should be safe.
You should also take a look at the tekin rs thread - I suspect you will find (use the search option) people posting other 21.5 setups either for touring car or vintage trans-am.
hanulec is offline
Old 07-08-2010, 04:12 PM
  #540
PrimeAKF11's Avatar
Ok, so I tried a 5.0 turn last Sunday. I used 30 timing with no turbo just like Jason Moberly's setup. I also used a slightly lower FDR than what I usually run for my fully boosted 10.5.
Although it had SCARY low end rip, I was disappointed with the top end speed. I would say that the top end was even a tick slower than my fully boosted 10.5 with v203 firmware. My lap times didn't come down much as it wasn't any faster on the straight (which is 200+ ft) while being so much harder to drive in the infield.
After a 6 minute run all of the leds on the ESC were blinking. The motor came off the track at 130 deg. I was using just one cap on the ESC with a fan just on the motor.
So what can I do to get faster? Try taller ratios? Turn the turbo on instead? How much can I expect the temps to come down if I use 2 caps instead?
Here's a vid of what the track is like.
+ YouTube Video
