Ask Team Tekin
#361
No. The esc is brand new, just got it from Stormer.
#363
I am not sure. I use it on a pan car in fwd/brk mode. When it takes some delay to start, I noticed that it may move slightly backwards begore going forward.
#365
I have the same motor but with the RS. Play with neutral width once you get a Hotwire thats what Randy advised and it did help. However I put in a sensored 13.5 and all my problems went away.
#366
Oldie....
Ok... here's one for the techies...
Don't laugh.... its old but its good
I bought a new Tekin P12C from one of the local hobby shops that had it lying in the warehouse as 'new old' stock. Got home, wired it up and set the throttle up.... So far so good.... then the problem showed up. On full throttle, the motor runs smooth and even. but on light part throttle the motor stutters like the brakes are getting pulsed on.
I adjusted my throttle EPA back to 100% forward and brake (was on 150%) and gave it another try. The pulsing/stutter is still there, but it occupies a larger part of the trigger movement (now approx 60% of the total movement from neutral; used to be less at 150% EPA).
I thought it might have been the TX/RX combination, so I swapped out the DX3R to a JR R1 w/Spektrum module... Still the same.... Swapped and tried 3 different motors from 27Tstocks to 11x3s. Still the same...
Anyone have any clue as to what is happening? I've been racking my brains and can't seem to figure it out...
Thanks!
Thanks!
#367
Im guessing you got the manual with it, if not you can download it here...
http://www.teamtekin.com/Manuals/P12...G12cIII,G9.pdf
It sounds like it might be a motor capacitor issue, but is only a guess. The manual suggests keeping the wires as short as possible too if thats any help?
#370
Hi, how did things go after the changes?
#371
just a thought but you could try setting your epa to 60% on the radio then re-program the esc... then up your EPA to 100%. see if that makes a difference.
#372
Tried different caps, external caps, 4 motors, and a whole other bunch of stuff... but no changes to the stuttering on low-mid throttle. I'll try the EPA on the radio this weekend...
I might also try another radio as I have heard rumours that the DX3Rs are not compatible with some ESCs... I'll see if I can dig out my old crystal radio sets and give them a try too...
Just about to give up...
#373
#375
On the DX3r you can turn down the radio's transmission frame rate. That's probably not the right name for the term but look through the manual.
If it's offering up a signal pulse too fast for the older esc the esc most likely will try to make the best of things and average. That will cause roughness and inconsistencies.
