Futaba 2.4GHz
#242
Originally Posted by rc-zombies
Here's the soon to be released 3PK-S 2.4ghz system with integral antenna...
j/k...I took the module apart and rerouted the antenna... If I only the coax cable was another 3-4 inches longer... I could do the mod.
#243
wire doesn't look like a regular antanna wire... looks like a mini coax cable. has twin contact connector at one end.
#244
Originally Posted by LORD SHADO
is this real or fake mod ,more info
http://www2.towerhobbies.com/cgi-bin...?&I=LXPZT7&P=7
the 3PKS system will probably look like my mod.
#245
hi guys, i have a problem with my 3PK & HRS Rx.....it is always glitching when the car is far away from me....i always clean up the rx with compressed air when racing..but still glitvhing....any help or advice???? please PM me.....bcoz i'm not regularly on line...thx guys....
#246
Has anyone tried the receiver from 3pm? The difference I could fins between the two is the DSC function.
#247
Here it is...
I used small silicone fule tubing to protect the antenna.
#248
#250
Trader Rating: 32 (100%+)
Originally Posted by jiml
According to the Futaba directions you need 6 volts for HRS to work. I switched my 1/12 just to see and had all sorts of problems. On PPM it worked perfectly.
#251
Originally Posted by Kevin K
Use a receiver pack and you can go back to HRS in 12th scale or any 4cell car.
#252
I called futaba tech support, and they sid it should work on 4 cell. so I am sending my rx in for a check-up
#254
Originally Posted by P2
I've been running mine for the past month w/out a rcvr pack and hd ZERO problems, I've spoken to a few sponsord Futaba drivers and they are not having problems either.
#255
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Futaba 3PM 2.4GHz
Anybody have a feedback on this radio yet ... Futaba 3PM 3-Channel 2.4GHz Transmitter/Receiver.
