2 centax adjustment questions.
Facts: Serpent 705, Centax-2, Sirio .12, EBMods, solid-cage thrust bearing.
1. Do you guys use the factory recommended endplay adjustment, or do you let it out a little more, for a harder engagement? Yes, I realize this limits the life of the thrust bearing.
2. Do you guys use the shims at the clutch spacer, or behind the flywheel?
Thanks.
Thanks.
Thanks.
Thanks.
