INTEGY 16X8V6
#31
Thanks for repling so quickly lookinco.
I have found out that I have the v6.0 chip (according to my lcd display). So from my understanding I have to set the cell capacity to above 3800 in the setup to achieve a full charge, is this correct? (I have just registered with the 'ticket system' so hopefully Integy won't take too long to send the chip out to me).
#32
updated info on my charger
I am currently getting approx. 3750+mah from a charge with the cells peaking at a temp around 115'F. I have the charger setup as follows:
1.)cell number=6
2.)battery capacity=3800
3.)phase1=6.0a
4.)phase2=5.0a
5.)phase3= 7.0a
6.)discharged=30a
7.)peak adj.=5mV/c to 30mV
8.)lock out= 500mah
9.)charge temp.=128'F
I have watched it charge a pack and it goes through all of the 3 phases fine. I am concerned that I am not getting a fully charged pack (due to temp and mah capacity).
Discharging the pack (30a):
2900+mah
approx 5:55 - 6:30min
avg volts 6.6
Should I be concerned? or do I have to adjust the peak cutoff value from 5m/v per cell to a higher value?
Anyone???? Can anyone provide any helpful advice???
1.)cell number=6
3.)phase1=6.0a
4.)phase2=5.0a
5.)phase3= 7.0a
6.)discharged=30a
8.)lock out= 500mah
2900+mah
avg volts 6.6
#34
Originally Posted by POOKYT
Anybody using this Charger???????? I need feedback from users or people who know the users!!! Thanks
Brant
Brant
#35
Originally Posted by xrayaustin
i own this charger and it is a fantastic charger. i have a turbo 35 and it is very close in comparisson to that without the graph. also it has a built in power supply so it runs of AC power. but overall it is an awesome chrger!!
#38
Originally Posted by xtrememadness
anyone have any serious problems with it
i did use the help desk, as hobbipro had advised. the process was fairly easy and the turnaround was about two weeks. the only problem is that they fixed my lcd screen, and disregarded my claims that it won't discharge because the "charger's too hot". apparently, it went back out untested.
by the way, since integy will fix it for free (again), i'll sell it for $100 and the buyer can go through the help desk this time. drop me an email.
[email protected]
oh yeah, the charger may emit a light scent of urine. i'm sure it will go away over time.
#40
ive been eyeing this charger for a long time. anyone have any serious problems with it charging ib3800s or have the problems been rectified with the new version 6.1 software. thanx
Also, the V6.2 chip now allows the user to manually adjust the mah capacity of each step and the thermal cut off for each step (which you couldn't do previously). Everything else seems to be the same.
One very happy customer now!!!
#42
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by TVMRocket69
They now have V.6.2 chip. Last I heard it was a 6.1
