Serpent 705
#496
Originally posted by tony montana
ok guys im new with serpent but I got a impulse pro from a trade. My question is, is this car just as competitve as the 705, do some of the parts from the 705 work on my impulse pro? Does serpent offer an upgrade kit for the impulse pro to bring it up to 705 specs? Or what parts do I need to upgrade to get it to a 705. Thanks for the help.
theres a few new improvements in this new car the 705 so to put your pro like a 705 is going to cost you so my very first advice to you is try to set-up your car like a 705 to see if you have good results there,, because the way they make the set up now is really diferent like they use to do it with the pro and the impulse, so don't give up it's a nice car you have there!!
ciao!!
#497
Originally posted by biker
thanks for the advice on part sources initialD.
Question for y'all on the serpent shocks.....is there some secret to building these shocks that I'm missing? I'm a new Serpent owner, but not new to the hobby....I've never had as many probs building air-free shocks.
Incidentally, these are the aluminum body shocks...not the stock plastic ones.
any advice??
Thanks again.
any advice??
Thanks again.
Bleed, Bleed, Bleed, until all the bubbles go away, then close it, don't worry if they are aluminum body's ,, in MY TSN they said that these shocks are to run in tracks that are extremely hot surfaces so the don't loose its consistency,,
sorry i'm just trying to help here a little!!
ciao!!
#498
Originally posted by PUNISHER
YUP YUP.....
I have the light weight alum. screws set and hollow shaft on my 705.
YUP YUP.....
#499
shock mountings
can anyone tell me the advantages and the disadvantages of the different mounting positions for the front and rear shocks.
#500
Originally posted by InitialD
Hollow shaft on the 705? Is that for the mid bearing block (808253) or is it for the 2 speed shaft?
Wonder where he get that and where i can get one.
I should have the same weight as him (3lb 12oz) if i had that install on mine, juz 2oz higher.
#501
Most parts are common to the 705. The 705 includes the upper deck (801190), chassis (801185), X brace (upper deck support) (801196), roll over bar (801123), fuel tank (801155) with associated accessories, battery holder (801171), front shock tower spacer (801117), new styled front pulleys and pully mountings (2 x 808265, 808225, 808261), new middle shaft (902252), rear bulkheads (bearing blocks) (801331, 801332), rear sway bar set (808337), brake plate (801342), new styled brake pulley + adapter (9616, 909248) and 18T side pulley + adapter (808260 + 808265), lowered engine mounts (801151), Centax II clutch + 35 mm smaller flywheel (909510 + 6581), new lightened 2 speed gearbox + new 2 speed shaft (902410 + 801415), rear ball diff + 46T + rear driveshafts (801430 + 6357 + 801323) and carbon graphite left + right side stiffeners (801192 + 801194), new keyed shockabsorber set (909440), new spring set (yellow 901415) and not forgetting the new purple sealed ball bearings. These are the parts that you need to upgrade it to 705 specs.
Serpent has a package for an upgrade kit (801182) for the PRO to convert it to 705 but I think it is still incomplete. I don't think there is a Centax II or the new lightened 2 speed gearbox. Try and shoot an email to rccarinternational. They have the upgrade kit to 705 but it is expensive. Serpent's site does not have any information on this yet. Don't know why. If you didn't have the PRO in the first place, then I say get the 705 straight away.
As for the Centax II clutch, the flyweights are different from Centax I. Then again, you could modify it the same like the Centax II. We have been using the modification long before 705 or the Centax II was announced. It provides better punch with the new styled flyweights. Look here for the modification;
http://www.mytsn.com/publ/publ.asp?pid=5674
If you need help, do not hesitate to ask
#502
Originally posted by nizee
Saw his car, the hollow shaft is for the mid bearing block.
You can get the mid hollow shaft at rccarinternational.
#503
Re: shock mountings
When the shocks are mounted more vertical, they are more direct and they make the shocks harder.
#504
Originally posted by ammdrew
use gs bladders, drill a hole in the cap for the bladder to move freely,
What do you mean when you say drill a hole in the cap fr the bladder to move freely?
#505
I always prefer to use aluminum shock bodies in front not because of performance but because they are more reliable. The plastic shokc bodies can break upon hard impact. The aluminum ones are impossible to crack. The front end always takes the abuse first if any.
#506
in four years i have only broken one body, but probably 5 shafts, just my exp,
gs makes a 1/10th o ring bladder set, the badder is larger than the serp ones, and a thicjer, they are harder to put together but will not tear or come apart nearly as easy, no website i know of, the company is general silicone,
the cap i am talking about the part that clicks onto the tower, goes under the aluminum, i drill a small hole through it to enable the bladder freer movement.......
#507
just one question, where did you get your lightweight aluminum screws?? ,, ther are original from Serpent or you get it from Ebay??
thanks in advance!!
ciao!!
#508
#510
Would that be the new company BOSS.
I have been talking with them and they will be making some parts for me soon.
