Serpent 705
#1636
Originally posted by markp27
Well I'll be! Right on my door step and I never knew
I've not studied the rules yet, as I won't be racing until the end of the season - what to get more practice in before getting on the circuit.
Which rules are you running to?
#1637
Does the 705 include a pipe and/or header?
#1638
#1639
No. You have to purchase both these items separately. It doesnt even come with a shell. But thats the price you pay to have a real race car
#1640
Since it is basically the same as the impulse, I am looking forward to it. I had a lot of positive results with my impulse. I was recently in a REAL car accident where my impulse was one of many things destroyed, so a 705 will be its replacement. I think that I am going to try the RD LOGICS pipe set.
#1641
I know what it was, it's the tool I use to take the glow plug out. It has 4 different socket sizes: 6mm, 8mm, 10mm and 12mm
#1642
No. The flywheel is mounted on a locking collar (the brass collar which has a split along it. If you hold the flywheel with a pair of grips and start tightening the shaftnut the flywheel will compress the collar and lock the flywheel tightly onto the shaft to prevent it from spinning.
#1643
but wont the crankshaft start turning after a bit?? cuz thats wat happend on some of my other engines...
#1644
i mean when ur turning the pilot shaft onto the crank, wont it turn the crank??
#1645
No. It cant. The shaft would only start to turn once the flywheel would compress the collar and lock it onto the shaft. But since you are holding the flywheel with a set of grips you are actually not allowing the flywheel or shaft to turn in the same direction as the nut.
#1646
ok... ill try that... so you never used an piston locker??
#1647
Never. I believe that constant use of a piston locking tool can damage the piston and conrod.
#1648
ok... thnx... if it werent for stupid exams id be so much for happy... and in a better mood...lol
#1649
Hey guys, I was just around running my 705 around my driveway and I didn't go more than half throttle. Well I came back in the house, inspected the car, and there was this mysterious oil liquid type stuff on the bottom of my chassis. I have no idea what it was, I can't identify it and it doesn't look like any oils i've used before. I wasn't driving hard at all or anything, i'm also running 30% fuel if that has anything to do with it. Does anyone have any idea what this oil is?
Also, my receiver battery dies after like 20-30 minutes of driving, even if I fully charge it right before I go out. I'm charging it at 3.5 amps if that helps. Any ideas?
Anyways, here are pictures of the mystery oil:
#1650
Picture 2:
