Tekno RC EB48.3 Thread >
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 02-01-2016, 04:36 PM
  #1171
RC Matt's Avatar
Originally Posted by HoldDaMayo
I run 18t on a 2050kv tekin setup, probably very similar to a 19t on 1900kv. I feel it's got plenty of low end and plenty of high end... Temps are also generally under 180 depending on ambient heat.
How long is your straight and do you think that 18t would be a good starting point or should I go up to 19t?
RC Matt is offline
Old 02-01-2016, 07:13 PM
  #1172
Mizchief's Avatar
I run 18t 1900 everywhere with current limit around 40-50% I'm just used to the feel more than anything, would only go up to a 19t if I was just getting beat down the straight
Mizchief is offline
Old 02-02-2016, 04:17 AM
  #1173
RC Matt's Avatar
Well I guess I'll just figure out what the people at my track are running.
RC Matt is offline
Old 02-02-2016, 06:13 AM
  #1174
Numburn's Avatar
Trader Rating: 11 (100%+)
I believe most run a 19t, but a lot do run the 18t including myself. I've even seen some run 17t. Start with 18, but keep the others on hand in case you feel you need more or less.
Numburn is offline
Old 02-02-2016, 09:56 AM
  #1175
I run a 19t. I don't change it out based on the track.
qstorm777 is offline
Old 02-02-2016, 07:13 PM
  #1176
R1Joel's Avatar
Anyone experimented with lower rear diff fuild? 3000? I drove a buddies EB48.3 today and it was alot easier to drive than mine. One of the only differences was lighter rear diff fluid. I was going to change it over but I read the JQ setup book and it said it would have the opposite effect. Make the car harder to drive. I'm currently running 7-5-5.
R1Joel is offline
Old 02-02-2016, 07:36 PM
  #1177
mkl
yes, I have been running 3k and just put in 2k to try out. At the moment I 7/7/2 but have not been able to run it yet.
When I was running 3k I had 7/5/3. It seemed to work well, the only issue I had was on-power push. Of course there are many other set up adjustments to help.
mkl is offline
Old 02-02-2016, 08:19 PM
  #1178
justpoet's Avatar
Trader Rating: 16 (100%+)
Regarding pinions, I've been running 18t on the 1900kv motors on 4s everywhere. I've seen folks like Lutz also run 19t on tracks like DNC. It is more about throttle feel than the straight in most cases. On that same DNC track last year there were also successful team drivers running 17t pinions on the 1900kv motors because it made several of the jumps a lot easier for them to hit at the right speeds (to not overdo it). All 3 should work out fine for you, though 18t is where I would suggest starting with either the 1900 or the 2050 in the EB, and then go up if the track layout is flowing and temps are good, or you find it easier to handle the throttle that way.
justpoet is offline
Old 02-02-2016, 08:22 PM
  #1179
justpoet's Avatar
Diff fluids tend to feel different based on the type of surface as well. Lower diff fluids tend to be easier to drive when a track is really loose and blown out and the car isn't leaning way too much, rewarding smooth drivers who don't want to break the wheels loose. Higher diff fluids tend to be easier to drive and more stable when the surface is more smooth or higher traction, and easier to drift with.
justpoet is offline
Old 02-02-2016, 08:27 PM
  #1180
SnotRkt's Avatar
Trader Rating: 13 (100%+)
New paint by Mels Shells. super stoked to get it on the track at Motorama 2016. Bonus pic of the big brother.
SnotRkt is offline
Old 02-03-2016, 05:56 AM
  #1181
mkl
speaking of diff fluids, what can one expect when keeping the same ratio but increasing the number? for example if I was running 7/7/3, what would the effect be if it was changed to 10/10/6? The ratio is the same but thicker.
mkl is offline
Old 02-03-2016, 08:24 AM
  #1182
Carter Flotron's Avatar
More stability, pulls over small bumps and track imperfections better, basically makes the car easier to drive provided you have enough traction for the thicker diff oils. Down side to thicker diffs is that you lose a little rotation in the corners, but there are other ways to get that back.
Keeping the same ratio and going up or down on thickness depending on the traction can be a very useful change for adapting to traction levels without changing the feel of your car very much.
Carter Flotron is offline
Old 02-03-2016, 12:38 PM
  #1183
SnotRkt's Avatar
Anyone using any other shock springs other than Tekno? looking for a full kit of option springs...
SnotRkt is offline
Old 02-04-2016, 04:11 AM
  #1184
jmcelroy42's Avatar
Look on the first page of the EB48 thread there is a big chart of all compatible springs.
http://www.rctech.net/forum/electric...48-thread.html
jmcelroy42 is offline
Old 02-07-2016, 05:54 PM
  #1185
Mizchief's Avatar
I depends on traction and your driving style. If you are more of a "F1" style driver with low wheel spin, lower rear diff on lower traction will let the diff action work easier and let you rotate faster without the back end breaking loose, but if you are a drifter lower rear diff on low traction will cause you to diff out faster and wash out the back end. Where thicker rear would help driving with the back end drifting more stable of a slide.
Mizchief is offline
