Tekno RC SCT410.3 Thread
#2071
I went to adjust my anti squat tonight and I am not understanding correctly how to do this. On the set up sheet in the back of the manual I believe it says its 3* if you build according to the reference pictures on page 7 which I did. What I dont understand is the pictures on the bottom of the set up sheet. There are 7 different dot positions and for example two different positions will both yield 1* Can someone chime in and straighten me out here. I want to reduce the rear squat from stock
#2072
#2073
Thank you. Still not fully understanding the pictures in the book though. For instance in the set up sheet the pill box on the bottom right shows 2 dots one on bottom middle and one on bottom left. There are also 2 arrows first shows one pointing straight down and says 1* and the other points to the left and says .5* What would that mean ?
#2074
Ok so I'm at the shock build page and stuck. It states that "vented" is preferred stock build and the arrow points to the middle of the cap, do I drill all the way through the middle of the cap to essentially where the mounting screw will be?. Is this correct, or do I drill the hole coming out at a 45 degree angle with a 1 mm drill bit? Sorry, I haven't built many shocks.
#2075
#2079
I raced for the first time on indoor this last Friday and had a really good time. My take is the tires and the set up is extremely critical. I made a few small adjustments and the truck felt great. Had some Losi guys drive it and they thought it was faster than their SCTE, but they are just great drivers. I have been very pleased considering how horribly I have wrecked this truck and its still a champ!
#2081
#2082
#2083
Thank you. I think I am starting to get it now.
#2084
Hello peeps,I would like to get opinions on which rims fit the .3 best with little rubbing issues on front steering...My cyclone SCTE rims rub steering very badly full right and left..I can limit my right and left travel,but looks like I will loose quite a bit of steering...Any thoughts?
#2085
