New Schumacher KF2
#31
I've started building it.
The quad slipper is very well machined. Not sure how it will handle on the track.
Looking at it, I realised they've done away with the rear bumper....
#32
Another quality schumacher product.
#33
Ordered! Can't beat the service from dRC. I think they'll have Schumacher tires soon so I can order everything from one place.
I've never bought a brand new RC car before. My KF has been awesome and I've been slowly working my way toward all the go-fast stuff like the low grip conversion and aluminum upper transmission housing, so I thought I'd just buy the whole thing. Seeing these pictures gets me even more excited. Looks like a lot of value in this kit.
Does it come with a coreRC servo horn? Any additional springs? I'm seeing a lot of KF option parts on these things.
#34
#35
Guess I'll have to get the spring sets and aluminum upper transmission housing after all. At least the low grip motor option and drilled rear pistons should give me something to tune with.
#36
Gotcha on the ball diff. Wasn't much my favorite of things to build on the SV2. Would really like to try tuning it with the gear diff since a 6.5 is going in it. Belts, knuckles, and arms will be first spares. Track I run at is pretty high bite so going to run the new pro-line slicks. Hope the car can be tuned to be a grip monster.
#37
The ball diff from the K1/KF seems to be stronger and better than the old SV2 unit, mine lasts much longer.
#38
The ball diff just felt alot more sturdy, and probably because it has its roots back from the SX days and the fact it had to handle the load of a 4WD.
#41
On astro I could never get the SV2 diff to feel good, could never really pin point it but felt like the diff would unload and then bind up again mid corner, and it never seemed to last. Never had the same issues with my old SX3 or K1, nor with a ball diff in my KF. I have always wondered if it was because of the bigger diameter of the 4wd diff that helped it last and feel better.
I've got my KF2 waiting for me back home but I'm at least a couple of weeks and a 12 hour flight away. Seeing you all starting your builds makes me very envious, Schumacher cars always build very well and it almost seems as if it's over too soon. Awesome to see the engineering in them though and to know what others are missing!
#44
Has anyone tried the MIP ball diff? Is there any improvement over the K1 ball diff? The main thing I would of liked is slightly longer driveshafts as I found the stock ones on the KF could pop out if running a more droop and rear toe. I could use the KR shafts but are the MIP ones any longer than the stock KF/KF2 driveshafts.
#45
If your running so much droop the driveshafts are popping out thats simply way too much.
