Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 12-12-2015, 07:58 AM
  #1726
I think this is a nice feature as when you bent a shock shaft you just have to change inexpensive plastic part (the lower white part), just have to stock them up just in case. I would rather buy those parts in case and change them than damage the cartridge cap, way more expensive.
One thing to know about gullwing parts is you need to order longer shock ballcups SD-008RC or the spring retainer will catch the wishbone before full droop.
Your choice to keep a higher droop value (I did and like it a lot) or to use shims behind pistons to keep stock droop.
mojo tom is offline
Old 12-14-2015, 10:50 AM
  #1727
I got my car pretty much all finished up last night (just need to solder the motor wires) and decided to weigh it. I added 50g of weight under the battery and with those in place my car weighed in at 1508g!! Absolutely incredible I can't believe how light this thing is. Definitely going to have to get some more weights for it haha
Levelup is offline
Old 12-14-2015, 03:26 PM
  #1728
What other light weight parts do you have on the car? Mine is sitting at 1504 with ti turnbuckles and the light body as the only light weight parts on it. I am using an Orion shorty. I do not have any added weight in the car.
afm223 is offline
Old 12-14-2015, 04:20 PM
  #1729
Speedo, servo and motor can have a lot of impact on the final weight... Switching screws for titanium can also save you around 25g... Add all that up and you can have 100g difference easily. And it has nothing to do with quality of the electronics... Some of my motors have as much as 40g difference!
Martin Paradis
rhodopsine is offline
Old 12-14-2015, 04:46 PM
  #1730
My car is stock out of the box. No ti parts I just added the dual slipper assembly. So not sure why my car is so light. Without the added weights it was @ 1454. And that's with a viper ESC, viper motor, orion shorty, spektrum sr300 reciever, and a mini turnigy survo for my airplane (temporary) plus Schumacher minipins rear, staggard rib lowpro fronts.
Levelup is offline
Old 12-14-2015, 06:47 PM
  #1731
That's another one I didn't think of, but there are big difference in weight between tire/inserts combos. A lot of the difference might be coming from that.
Martin Paradis
Old 12-14-2015, 06:52 PM
  #1732
Martin Paradis
Yeah very true. I'll weigh it without any tires or wheels and see where its at.
Levelup is offline
Old 12-14-2015, 08:08 PM
  #1733
Martin Paradis
Orion shorty, Factory RC battery brace, Proline Electrons with Proline inserts on Associated 2.2 wheels, Justock xr10 esc with fan and has wires trimmed, Ecopower 17.5 motor, Associated springs front and rear, Protek 100ss servo with aluminum horn, Trinity drilled 3w tooth pinion, JConcepts 69 tooth spur, JConepts aluminum wing buttons, aluminum upper shock mounts (not caps), ti turnbuckles, light body, futaba fhss receiver.
All of the above equals 1504 grams.
afm223 is offline
Old 12-14-2015, 09:03 PM
  #1734
1339g without my Schumacher astro tires on pre mounted wheels. I'm also running the factory rc battery mount. My lipo is 221g debating putting a stock motor in this car haha my tlr22 is 1603g 😩
Levelup is offline
Old 12-17-2015, 03:43 PM
  #1735
Default chassis
Anyone know of anyone that Makes a yz-2 chassis
CaseyBecica is offline
Old 12-17-2015, 03:50 PM
  #1736
OriginalDonk's Avatar
Trader Rating: 44 (100%+)
Did you taco your custom YZ-2 chassis Casey?
OriginalDonk is offline
Old 12-19-2015, 09:47 PM
  #1737
Struggling for rear bite. Anybody cut the waterfall, or remove motor plate brace? I've notice on most all Lee Martin's cars there is no brace used.
hyperdive08 is offline
Old 12-19-2015, 09:53 PM
  #1738
joeymdz's Avatar
Trader Rating: 13 (100%+)
Removing the L brace aids in more rear flex but explain what surface you run on and what setup are you using?
joeymdz is offline
Old 12-19-2015, 10:30 PM
  #1739
Running on med/high bite carpet track.
Using lee Martin's trencin eos setup.
Car seems to be loose on mid / exit
Old 12-19-2015, 10:40 PM
  #1740
joeymdz's Avatar
Are you using the bmax rear arms? If so you could get extra traction by moving the rear hubs all the way forward. You could also go down in diff fluid. Use 2-3k
joeymdz is offline
