Clutch Problems
Clutch Problems
I have an rc10gt. For some reason everytime i run the truck for 2-3 tanks i manage to break the clip that holds my clutch bell on, when that falls off, my clutch bearing falls out then the cluch wobbles and frys my spur gear, its happend like 4 times already the exact same thing, the second time it happend i replaced the clutch and it still happend.... any ideas whats causing this? or a cheap way to fix it? ... i have a Megatech .16 motor
yeah its the right sized clip, i noticed the last couple times theres little shavings of steel inside my clutch bell, the bearing or something is starting to shave my clutch bell. Im probably just going to end up replacing the entire clutch bell assembly. I think when i shortened the pins on the flywheel for the new clutch i may have bent one or made it off balance
