Team Associated T5M Discussion
#1396
#1398
It's 0.5 degree difference of inboard rear toe. He apparently wanted to get the rear a little freed up it seems. You can accomplish that via other tuning methods. While not exactly the same, you could run the 2/1 C block and then add 0.5 outboard toe on the rear hubs.
#1399
2.5 toe is gonna free it up on throttle but its also going to lock it in from over rotating in tight low speed off throttle corners, and based on the tendencies of stadium trucks i have to assume this is why he went with less toe.
#1402
I've ran the truck once. Really happy to be driving ST again, but not happy with rear traction.
I have to say thanks to AE - the "rear motor" arms on the B5M is a sweet change for less wheel base and more grip. AE recognized this and built the T5M with the shims in the C and D block so we can have the same option like the B5M does.
Just shortened my wheel base all the way in search for more rear bite. Running modified with a Trinity half brick and a 7.5 D4. Also lowered the rear ballstud, and going to pickup the schelle rear ballstud mount for the optional longer mount.
#1403
#1404
my kit is on order eta is late apil
#1405
Went to the brass C block and went 3-2 for anti squat. Really happy with the truck now. Also went full short on wheelbase - thanks AE for allowing me to move the rear arm!
#1406
I'm having an issue where the rear of the battery strap comes out of the slot. Never had this happen on the B5m, but it's happened a few times now on the T5m. The only way I can see this happening it if the chassis is flexing enough to allow the strap to come out of the slot. The blue thumb nuts are tight and stay tight; it's a little baffling. I'm running saddle batteries, so when this happens, the saddle tries to sneak out.
#1407
#1409
T5M Wing
Do not see on teamassociated.com. Anyone know where we can get a wing replacement without having to purchase the entire body?
#1410
