Team Associated T5M Discussion
#2791
I'll I'm going to say about running a lot of motor is that the stock guys at most tracks run faster than mod. The best local drivers [where I am] can run a tenth or two faster fast lap but cannot do it consistently and still have better runs in stock than mod. These are all sponsored guys. If you're a really good driver you should be able to rail like a madman with a 13.5. I've only been on 1 track open enough to where you need more than that. A majority of the tracks that people seem to be on across the country do not have enough straights to necessitate a true mod motor. 6.5s and 8.5s should be left to the super experts and pros....in my opinion.
#2792
R/C Tech Elite Member
#2793
Looked these part numbers up and the front ones are 54mm long which I believe are like the short ones that originally came in the kits, while all the rear ones are 72 mm long. I was wanting to go with the longer ones all the way around like Ryan C. had on his at the ROAR Ntals.
#2794
Nothing on the setup sheet says that. Just says white springs front and rear and the fronts look like standard front springs. The 54mm springs are quite a bit longer than buggy front springs. 10mm to be exact.
#2795
Anyone running a shorty with double stick and no battery strap? How did it effect the truck?
#2800
I think the new truck springs are the same as the Kyosho springs. Its interesting because I use to be able to tell the difference simply because the AE springs are wound in the opposite direction. When you look at the new springs they are wound in the same direction and the spread between each coil is about the same.
#2801
Turf time
I've started to run my T5 on turf and am looking for some suspension help. I have a stock setup on it now besides 2 shims in the shocks to lower/limit travel. I'd like to get it to track flat around corners with very little roll. Any advice with shock setup that I should try to achieve this?
#2802
Not 100% sure but maybe a sway bar would help some.
#2803
Gray springs, 37.5 & 32.5 oil? Would stiffen it up, but I would be concerned about rolling it over. Here is Jesper Rasmussen's set up from Petit RC for carpet. He goes even heavier than that...
http://site.petitrc.com/setup/associ...ich2016012931/
#2805
