Tamiya TB Evo 6
#2043
When the car is off the ground then the arms must be able to naturally angle down slightly or at least be level (droop).
When the car is on the ground then the arms should angle up slightly- that sets ride height, not droop. The springs must set the ride height, not the droop screws. Springs are too long if you can't get down to 5mm by adjusting the collar.
Time to take your car to the local track and get the local pro to help set up that ride height and droop
#2046
CORRECT.... You should also have zero preload on the springs at full droop at all times: you should see a little up and down play in your springs at full droop...
By saying that then you are still trying to use droop to limit ride height. That is causing the problems...
#2047
Nubs,
Here is what I notice from your pictures.
I'll be at Ripon tomorrow with fresh batteries in my digital calipers. We'll measure everything and get it figured out.
- The downstop adjusting screws in the lower arms could be limiting your achievable droop.
- The anti-roll bar connectors could be at a length and geometry where they are limiting full movement of the lower arms. The front connectors look to be angled inward too much (probably should use the inner arm studs for mounting).
- The aluminum damper mounts should eliminate the need to use a long upper ball stud spacer. I believe you only need a 1mm spacer, per the TB Evo 6 manual. This could be affecting suspension geometry and achievable ride height.
#2048
Nubs,
2) Made the appropriate changes to the ant-roll bars
3) Made the appropriate changes to the damper ball spacer
Thanks!
#2050
Disconnect your shocks and say bars. Then turn the droop screws way out or remove them altogether. Your arms should hang pretty far down. If not, it's something on the chassis preventing it. If the hang down, then the issue is with your shocks being too short for one reason or another.
#2051
Make sure your hinge pins and other rotating parts are not binding: ballcups, C hubs, Cvd's, dcj's, etc...
#2053
Ok guys, the best thing you can do now is go on the "Capricorn America " YouTube channel and watch Dj Apolaro's shock & droop tutorials amongst all the tutorial videos that he posted there. They are priceless !!!!
