STOCK motor forum
#1771
Oops, my fault. His signature mentioned Yokomo.
#1772
Originally posted by DOMOisCOOL
To figure out FDR (Final Drive Ratio), find out the internal gear ratio of the car first. I believe you are driving a Yokomo SD? If so, the internal gear ratio is 2.35. Then find out the spur/pinion size.
Ex:
Spur/Pinion= ??? x 2.35 = FDR
72/21= ~3.4 x 2.35 = 8.0.
Hope this helps.
Ex:
Hope this helps.
You guys are great, thanks 4 all the help & keep it coming .
-JayBee
#1773
Monster stock - 24-30 rollout depending on the track. I run a 25-27 rollout on a medium sized track.
Q? - Is the BRCA Binary 2 magnets?
#1774
I run the Orion Core Stock motor.
When a local expert at the track tested it, he said it was a very slow turning motor. He said it must be a torque motor. I have no clue. I am running my TC3 with stock pinion and 25T spur. I can't figure out if I'm getting outrun in the straights due to cheap batteries(Reedy BlackLabel 3300), cheap ESC (Duratrax AutoSport), or wrong gearing.
So, is the Trinity Monster a better motor for a beginner? Dang I dunno about all this stuff.
#1775
The Core Stock, Reedy MVP and Peak Hellfire are basically the same motor...based on the Reedy/Yokomo can I think!? They are torquier motors and would require a larger pinion. Based on your gearing, you're around 7.2 final drive ratio. I run my Cores around 6.25. A good tuning tip is to run them with narrowed brushes (0.140"). This is a "Big Jim" tuning tip and it's always worked for great me.
#1777
The Mvp uses a yok can and endbell. The orion and peak use a Top can and endbell.
#1778
How many of you guys own your own mini-lathe's to cut the comm's? I'm new to this hobby and was wondering if I needed to pick one up. I'm just racing stock, anyways.
#1779
#1780
I've got a lathe. My best two investments in this hobby were a decient charger and a lathe. I'd say get one if you intend on racing every week. I cut after 4-5 runs and it's really much easier then asking others to cut your comm. If you'd rather not buy one just yet, offer someone a bottle of soft drink or a few bucks and they'll cut your comm for you.
Just a note, it's very annoying when you cut someones comm and it takes alot of passes to clean it up. At least have your comm cut every 8-10 runs if your racing.
#1781
I have a P2K2 that should be in next week. Lemme know what you guys think!
#1782
See www.rctechonline.com for their race schedule.
Might need about $3 to buy replacement brushes to go with the comm cut.
After seeing some racing and talking with the locals, you should be able to decide about buying a lathe for yourself.
#1783
I have one but right now Im at the point that I do more harm than good when i use the thing.
Not good at it at all. And are more about cleaning them instead of cutting them.
#1784
Originally posted by XXX-S Bill
Just show up for the racing at RC Tech in Daly City and someone can cut the commutator for you. I did three other racer's motors this past Sunday. You don't even have to be a "racer" for us to help you out.
#1785
i have a rtr tc3 and i plan to upgrade to a reedy spec 19t quad magnent motor, and i was wondering if i should just use the stock spur and pinnon gears with it or get better ones?
also is their so way to figure out a motors mph?
