Serpent 960....
#1681
hm, i will try it i think
i have heard that the alu brake pulley are eating rear belts.. any experiences with that?
#1682
I have had no problems with the aluminum pulley that is on the 2 speed shaft.
Make sure the pulley is seated properly, directly over the flatspot on the shaft. Use Loctite on the set screw before screwing it in.
Also make sure you have the aluminum pulley aligned evenly with the 51 tooth solid axle with the rear belt on. If you do not have these properly aligned you will have a much higher chance of destroying the rear belt.
Hope this helps.
#1683
Originally Posted by going4#1
Anyone using the new fuel lid? Anyone getting a leak? After putting on the new lid my fuel tank now leaks from the rear of the new lid. The leak isn't super serious but I'd rather not have it. Any solutions? When is the new 125cc with silcon ring lid coming out?
#1684
Rob
#1685
Suspended
#1686
Ok, hmm... i dont know if i go and buy it.. too few experinces with it.
but i still wonder what can make the 960 lighter... any suggestions?
and roll more light
and roll more light
#1687
Suspended
and roll more light
and roll more light
Roll more light? This is a matter of perfect material matching and apply ceramic bearings. The mechanical roll will come after some driving
#1688
Originally Posted by PMSorber
Alu srewset, lipo, LGC, hollow middleshaft, light lever's, QC wheel axles or CV, light weight body ... our car can be less than 2500 grams
Okey, i will get alu screws and titan screws... maybe the lgc, the light steel axle...
As far as i know the pro belts are doing this very good.. the car rolls reaaally smooth and light
i think i would get some titanium parts..
#1689
Put in some baloons, filled with Helium, this will make the car lighter......
#1690
Suspended
We tested the pro belts, the rear is to long... We only apply them as sidebelt.
#1691
Suspended
#1692
Be aware that titanium parts and steel do not mix! (bearings on a axle)
yes, i mean the pro belt on side and in front.
#1693
Aluminum screw set is by far the best bang for the buck when it comes to lightening the car. Lipo is nice, along with Titanium Pillow Balls.
#1694
Hmmmm ... a light explosive car!
#1695
Aluminum brake pulley is great. I wouldn't run without it! Had problem with stock set-up...set screw backing out & getting jammed between adapter & plastic pulley. What a pain! Set screw is fully visible for inspection on alum unit.
