GMVIS COMMANDER battery Charger Questions
Hey .. I have just got one of these chargers.
Can anyone recommend what settings (amps & mili-volts) to use to charge GP 3300 & IB 3600 when using the "GMVIS Charge Process" ?
I don't know if the commander has the proper software to charge the newer NIMH cells. As far as I know the voltage cutoff is too high, and in the versions I have seen not adjustable. This means it will overcharge and damage these cells. You should call the horizon service center and see if there is an upgrade for this charger that will make your cutoff voltage adjustable/ selectable.
Hi Mazmo
You change the cut-off voltage in the cycle menu. Set the cutoff to 20mv.
When You use the VIS charge, You should use 8Amps or 9Amps.
The charging method is special, so 8A VIS is equal to 5A "normal", 9A VIS is equal to 6A "normal".
The charger is built to charge all type of cells. If You don't have the newest edition of the software, You can buy a new chip with the 2005 software. Contact GM-Racing or Your dealer. www.gm-racing.de
I hope this helps You
Søren Boy Holst
Denmark
Team X-Ray -- Team GM-Racing
Søren Boy Holst
Denmark
GMVIS Commander
Originally Posted by SBH
Hi Mazmo
Søren Boy Holst
Denmark
Søren Boy Holst
Denmark
Hey SBH ... thatnks for that . I tried charging my 3600nimh at 7 amps using the GMVIS Process with 20mv cut off. The cells seemed to get very hot. Do you know what may have caused this ? Would appreciate your response.
Thanks mazmo
Hi again
The cells gets hot with this type of charging
I use these settings when I use VIS charge
8-9A
55' celsius
Max 4600 mAh
12v
0,20mV
Søren
8-9A
55' celsius
Max 4600 mAh
12v
0,20mV
Søren
GMVIS Commander for sale
Originally Posted by Mr. Shookie
If either of you know anyone who would like to buy a Commander please let me know. I have a commander with the most current updated cpu just got it two months ago so it will do Lipo's now. It is the newer version with the two outlets up front.
Thanks,
-Shookie <><
Thanks,
-Shookie <><
I will ask around at the track . how much do you want for it ?
Mazmo
Hi again
8-9A
55' celsius
Max 4600 mAh
12v
0,20mV
Søren
8-9A
55' celsius
Max 4600 mAh
12v
0,20mV
Søren
Thanks for that. I tried the GMVIS Process at 8 amps on my GP3300 however the pak peaked at 2750 mah. Voltage was about 9.3.
The ending mah capacity seems low, the paks usually reach 3850 mah on peak charge. What capacity do your cells usually reach ?
Can you recommend how I can increase the capacity using the GMVIS Charge method ?
Would appreciate your assistance.
Regards
Mazmo
Originally Posted by nitro kid
hey i just got one of them charegr but i do not have a power supply do you guy know where i can get a cheap one or can i get it to work with not it i need your help asps
http://www.buyreliant.com/psupplies/psv200.htm
best for the $$$$$.
-Shookie <><
how do you use this charger i will be chargering 2000-3300-3800 want do my charger need to be set at
I have 3300 & 3600 - I use 20mv and charge at 6.0amp PEAKCHG or 7.0amps GMVISCHG.
I also set maximum capacity to 3800mah for the 3300 cells and 4200mah for the 3600 cells.
You might be able to set maximum capacity for your 3800 cells to about 4400mah.
Hope that helps
yes that help what about 2000 battery what do it need to be set at
Well .... the operating instructions recommend be 20 to 30 mv for nicad batteries. 30mv should be OK.
I think you could PEAKCHG at 6.0amps or GMVISCHG at 7.0 to 7.5 amps
On GMVISCHG max capacity should reach 2500mah if the cells are in good condition, or about 2200mah on PEAKCHG.
Do yo have operating instuctions ? Let me know, I can email to you if you don't.
Hope that helps
