Xray T4'14
#1141
#1143
So I need
FF,FR,Split blocks and RR also roll center inserts.
Arm pin front and rear
Closer lay shaft holder L&R
Lower deck
Steering plate....
Any things els?
Yiming
Lower deck
Steering plate....
Any things els?
Yiming
#1144
The arms are different. The new arms can be used on the older car with 2mm of shims but the older arms wont work on the new car. The top decks are different only where the center post mounts. If you don't plan on using the center post then you can use the older top deck.
Front arms are not the same. The '14 items are longer at the pivot pin end, so old wishbones would require an additional 2mm of shims, but will still fit.. BUT.. The new wishbones are also thicker on their leading edge, so the shock mounting point is actually further forward than on the old car, think it's 2mm, hence the new car also having 2mm at the top of the shock in the kit setups.
top decks are different, but if not using the centre post, either will fit.
#1145
I find that is far abit of money to make my 13 to 14
Yiming
Yiming
#1148
Looking to cure a mid corner push. I race on a med traction asphalt track.
Basic asphalt set up except for the following.
400 cst in the shocks, front diff,1 mill. 28 sorex. Track temp around
60deg in morning 70-75 in afternoon
Thanks for the advice
#1149
I'm running the t4 with a few 14 bits fitted, I fitted the wishbones so I can try the plates, no mod needed.
#1150
Can you fill in a setup form on Xray's site and post a link here.
Skiddins
#1152
Another small change would be to add some front arm sweep (use .5 out inserts in FF).
Bigger change would be go to reduce rear toe (.5 in on RR or .5 out on RF).
If you lose initial steering from any of those, go thicker in front shock oil.
You can also try more front camber or less rear camber.
If that doesn't work, then I haven't learned anything this week!
-Mike
#1153
