tire prep help
tire prep help
Do you guys clean your tires every round and if so what with?
Most people dont but ive definitely noticed a difference since cleaning tires. I use brakleen and sauce immediately after. Alternately you could use rubbing alcohol but i find that drys everything out a lot. Some say brakleen does too but the tires dont last long enough to see a difference i think.
Really depends how dirty the racing surface is. I find bathing the tire in water works better against sugar water solution outdoors.
Lighter fluild also works well as a cleaner for both foamies and rubber tires. It's cheap, and I havent seen any real drawback. The only tip I could give would be to let the lighter fluid tire dry for a while before re-applying your sauce, or dab some sauce on a rag/paper towel and wipe off the lighter fluid residue before saucing.
For on road we use goop hand cleaner for cleaning use micro fiber to wipe off then use tire sauce of your choice On carpet VTA after frist round we just clean with goop no other tire prep need
I use liquid tire buffer and wd40. I first wipe the tires with the liquid tire buffer, was told it opens the pores in the rubber, then I apply the wd40, which softens and condtions the rubber, or so I've been told. I use a separate rag to apply each. I then heat the tires with my MuchMore tire warmer.
