Tamiya TRF418
#1771
Ha. You guys are running stock or 21.5 and are afraid of sticking the servo half a centimeter further out?
And why would you use that when you can get an Xray servo mount that doesn't have any of those problems?
#1772
I just wonder what the point is? The Tb evo mount is more likely to tweak than the kit one as its made from separate parts, the std TRF418 one is very tough, and its also more inline with the chassis, so its a win win situation.
#1773
@Qatmix
I have not yet made a setup, because I'm still waiting for my 54580.
I give you notice how it affects.
#1774
#1775
That car breaks more often at our track than the 418.....still want one though...
#1778
The evo mount fits under the shaft (along the centreline, and then the mount for the servo is alongside (like an inverse L) so fitting it to the centre of the car will just offset it by the amount of the part under the shaft (approx 9mm) moving the servo 9mm further out than the std kit one.
#1779
Anyone racing on carpet?
Share any tips or tricks. I'd think sharing items like how changing the roll center on the 418 would feel? Items we test in how the car reacts to certain changes.
I think I need a cheat sheet for setup for 418 lol
I'll be racing 17.5 blink this winter with sorex 28s with Smokem rc chassis!
#1780
#1781
#1782
http://www.thercracer.com/2014/07/ta...on-review.html
The track is quite tight, I do find a stiffer car is always a faster car on carpet. There is a base set-up there. I found the crazy 7mm shim ones just made a car that was really lazy but easy to drive.
#1784
Aluminum.
I have bent one steering turnbuckle before and replaced it with titanium.
